magnusfide
On the Road Again and Again and Again...
Is the nitro fill worth it on tires for either mhs or cars? Pros? Cons?
First law of science: don't spit into the wind.
Keep on rollin'!
Magnus
past-MIdirector
Michigan
Just do a search. It is not worth paying one dime for. The only difference between nitrogen and compressed air is compressed air can contain water vapor. The stories nitrogen does not leak back out is a myth. Nitrogen pressure varies just as much under load, temperature, and speed as good old compressed air.
wolfe10
Agree, but there are THREE choices:
Nitrogen, DRY, repeat DRY compressed air and WET air.
An air system with dryer will give you dry air which is very similar to Nitrogen in its properties.
Those coin op air compressors at convenience stores and those little portable air compressors don't remove the water. Water does NOT follow the ideal gas law (in terms of PSI change for a given temperature change).
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Devocamper
West Haven CT
I dont think it is worth it because when you need to adjust your pressure due the outdoor temps or loads your not going to have Nitrogen to use, I have a co2 tank for adjsting my pressures since I need 110 psi and the small compressors struggle to make that psi so I would be deluting the nitrogen each time . They say that nitrogen is not effected by tempature but I still think it is not worth it .
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
Old-Biscuit
Across the USA
Planning on hitting the race track for a few laps?
Otherwise regular 'air' is already 78% nitrogen.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
Jayco-noslide
Galesburg,Il., USA
Nope. Not worth anything but won't harm if it's free. Comes from Consumer Reports.
Jayco-noslide
magnusfide
Thanks much. Great info.
NewsW
US
Even if Nitrogen is perfectly dry, there is always some air in the tire and with it, moisture.
I fill my tires with a high tech mixture of 78 percent nitrogen, 1 percent argon, and 22 percent oxygen.
edited 05/26/12 01:54pm by NewsW *
bob34787
winter garden
lets assume you have your tires filled with nitrogen, where do you suppose you will get air from of you are running a little low, the local nitrogen refill station? I will stick with nitrogen/oxygen mix, thats what comes out of my compressor
full_mosey
Oklahoma
Eliminating the Oxygen inside the tire does nothing for the outside of the tire!
I don't see any Pros except for the seller.
HTH;
John
