RV.Net Open Roads Forum: Tech Issues: EMS energy management systems
 > EMS energy management systems
CT_WANDERER
E. Lyme, CT
Posted: 05/26/12 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I know what PI units do as I have it one. However some times people are not sure what EMS are when posting. That is why I was asking trying to clearify what was being looked for.
Hurricaner
Hurricane Utah
Posted: 05/26/12 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
That's because the dumb sh### at PD don't know what an ems is. It is not a surge protector.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
renoman69
Edmonton Alberta
Posted: 05/27/12 07:45am Link  |  Quote  |  Print  |  Notify Moderator
I have THIS EMS system im my fiver and it works great. It has save my electronics at least once that I know of. It is very easy to hard wire in yourself but if you are unsure of your electrical capabilities get an electrician to do it for you.
2009 Jayco Eagle Superlite 25.5RKS
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I,
270 watts of Kyocera solar
Blue Sky 3024i MPPT controller
450 AHs of Trojan power
Iota DLS-75/IQ4 converter
Hurricaner
Hurricane Utah
Posted: 05/27/12 07:56am Link  |  Quote  |  Print  |  Notify Moderator
You don't manage an rvs electrical system by shutting it down which is all the PD does. That is not management unless you consider a manager someone who fires everyone when there is a problem.
The ems was around a long time before PD incorrectly started using the term for there surge suppressor. I have nothing against the product but they never should have called it an ems. Look at the confusion it is causing in this thread, unbelievable!!!!
Sam
CT_WANDERER
E. Lyme, CT
Posted: 05/27/12 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Sam
See this is why I was trying to get clearification on what the OP was looking for. Terminology is great if we all us it the same way.
Lady Fitzgerald
Tempe, AZ, USA, Earth
Posted: 05/27/12 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Sam
PI (I don't know how you get PD from Progressive Industries) calls it an Electrical Management system because it does more than surge suppression. It also protects against over and undervoltage conditions, off standard frequency, and miswired pedestals (shut down is one heck of a lot better than damage). PI has been calling their units EMSs for a long time and this thread is the first I've seen complain about it. I've also have never seen it cause confusion before. I have seen what you are calling an EMS also referred to as a Load Management System (which is a much more accurate description than EMS).
Jeannie
Wayne Dohnal
Bend, OR.
Posted: 05/27/12 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
The load-shedding device manages the available energy, so I don't see why one word better describes it than the other. It's just unfortunate that two very different RV electrical devices are called by the same acronym. The Intellitec web site does a good job of defining the name and acronym up front http://www.intellitec.com/index.php/products/Energy_Management/, while the Progressive Industries web site does not define it at all. The only way I could find the name for their EMS was to download a manual, so IMO PI, by omission, is encouraging the wrong name to be associated with their device. I'm not the only one, at least one RV equipment dealer http://www.rvupgradestore.com/Progressiv........ment-System-240Volt-50amp-p/emshw50c.htm calls it by the wrong name (2nd line of description). I think it's great that the ambiguity was recognized in the 3rd post of the thread. Many other threads go a lot longer with people talking past each other until the terminology is nailed down.
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
Devocamper
West Haven CT
Posted: 05/29/12 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Hurricaner wrote:
Progressive industries strikes again. No it is not an EMS.
Sam
,Progressive makes both surge protetion and ems - portable and built in units, I like the portable 50 amp if I change trailers i keep it is was a few $$$
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
Hurricaner
Hurricane Utah
Posted: 05/29/12 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
OK, I think we have beat that horse to death but just for clarification PI calls the unit an electrical management system not an energy management system so they never should have been brought into this thread.
The big difficulty in retrofitting these units is the AC units which usually can't just be shut off and turned on by turning power on and off, you have to have some control capabilities. Other than that it is just a matter of tying into the existing panel and circuits which may be easy or darn near impossible depending on the location.
Sam
