RV.Net Open Roads Forum: Class C Motorhomes: do they all lean
 > do they all lean
bukhrn
Lanexa, Va
Posted: 05/28/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
"do they all lean"
No
2007 Forester 2941DS
2005 KIA Spectra
noe-place
Somerset, Kentucky
Posted: 05/28/12 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
My 04 Itasca Spirit has leaned from day one. It's a full 4" lower on the left rear than the right rear. Slide outs are on the left side as are holding tanks and genny. We never carry much in storage and only about 1/3 fresh water (on the right/center). I have air bags and if I get annoyed enough I will put more in the left to compensate but it doesn't affect the ride and the tires are wearing perfectly even at 35K miles.
j-d
Sunny Florida USA
Posted: 05/29/12 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Being under a parked RV is at least as bad for the springs as being under an RV that's being driven. Think of fifth-wheel owners. They get the weight off the back of the truck when they're finished with the trailer. Many remove or relieve the weight at the end of every travel day. We can't do that. It's a truck that's nearly fully loaded all the time. Not driven much and the springs only get compressed, not flexed.
We added a generic "repair leaf" to each side on our first Class C and everything improved. Ride, Level, Sway.
Current one doesn't have slides, is pretty light for a 31', and has been driven frequently. It doesn't sag in the rear. Not either side or all across.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
Paoli
Quesnel BC
Posted: 05/29/12 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Dakzuki wrote:
Tune the radio to a station with Rush Limbaugh. If might get your RV to lean to the right and correct your issue.
LOL
bukhrn
Lanexa, Va
Posted: 05/29/12 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
bukhrn wrote:
"do they all lean"
No
Actually, I need to quallify that statement, mine does NOT lean to one side, it DOES set low in the front.
rehoppe
Denver & Nathrop Colo or somewhere else
Posted: 05/29/12 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Paoli wrote:
LOL
But it May deveope a need for medication?
Hoppe
2011 Dodge 1500 C'boy Caddy
2000 Jayco C 28' Ford chassis w V-10 E450
Doghouse 36' or so Trophy Classic TT
crawford
Dandridge Tenn.
Posted: 05/29/12 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
boy it's getting better all the time
Grandpa Joe
Posted: 05/30/12 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2011 28 ft sunseeker, the passenger side of the coach area is about 3/4" lower than the driver side, the Ford E450 chasis looks pretty level, wondering if it may be missing a shim, contacted Forrest River and they were not too concerned with it but made a note in my file. No handling issues, if I let go of the steeering wheel, no pulling either way.
Rolin
Oregon
Posted: 05/30/12 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
23ft Jayco
Right front is 1 to 1 1/2 inch lower. I took it to a scale and the right front is about 300lbs heavier. No idea why. Didn't notice any lean when we first got it.
Thinking of adding spacers to the front coil spring to raise it up a little.
dleslie125
Southern Ontario/Palmetto FL in Winter
Posted: 05/30/12 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Kind of dangerous. It could tip over.
2011 Itasca Impulse 26QP Silver Toad 2011 Escape Ltd AWD
New W-I Class C Yahoo Group
07 Jayco 32SS on Kodiak • 06 HR Amb 40PLQ ISC 330/950 • 04 Winnie Jrny 39W CAT C7 330/860 • 2000 Triple E Cder F53
Prev toads • 07 Tahoe LTZ • 04 Colorado Z71 04/06
 > do they all lean
