RV.Net Open Roads Forum: Fifth-Wheels: Michelin Tires 17.5" J rated and cracking!
 > Michelin Tires 17.5" J rated and cracking!
bigdon68
Churchville, Maryland
Posted: 05/27/12 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
RAINEYTXX
Lets us know how you make out. My Michelin 17.5's are the XTE2 and they have been fine.
Good luck.
bigdon68
2008 F350 CC 2WD LB 6.4 Lariat Auto SRW, Retrax, AirSafe Hitch, CB, Train Horns, On-Board air, RideRites, Aux Tank
2007 Ameri-Camp SummitRidge Reserve,40ft, Onan, MorRyde IS, Disc Brakes,17.5 Alcoa Wheels, Michelins, dual AC, Bigfoot Levelers
MY PICTURES
JTrac
Oklahoma
Posted: 05/27/12 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Those tires are what are coming on our ordered fiver. Sure did not know about the 62 mph limit. Wish I had known about it before ordering. We like to cruise at about 65 so may not be a big deal but still seems odd to build a tire for highway use on a trailer with that kind of limit.
JimT
2013 Excel Winslow 34RKM pulled by a 2012 GMC 3500 Denali diesel, faithfully assisted by my wife and the two Bostons
Snow_King
Gold Canyon, AZ
Posted: 05/27/12 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
Could someone clarify what is being said about inflation. 6 of these tires at 120 lbs inflation equals 28830 pounds of capacity. Seems even a MS is not going to have that kind of weight on its axles. Michelin CS typically will recommend using the inflation chart at all wheel positions.
Somewhere in a Fifth Wheel - Where it does not Snow
FastEagle
Taylors, SC
Posted: 05/28/12 12:25am Link  |  Quote  |  Print  |  Notify Moderator
When reading tire manufacturer recommendations about tire pressures it would be best to get direct verification from them via email or phonecon. Tire manufacturers will not dispute a vehicle manufacturers responsibility to set tire pressures. It’s a complicated subject with many government regulations and safety standards being involved.
FastEagle
Dickinson, ND
RAINEYTXX
Texxxas
Posted: 05/28/12 05:12am Link  |  Quote  |  Print  |  Notify Moderator
Those are the stock tires on the Suites-these are NOT replacments.
Low tire pressure did not cause this-I check them all the time. I think the tires can carry more weight than the whole trailer is designed to carry~! Tires are also shaded by the slides on each side.
I did read about 62 mph speed limit-no problem there.
Defective tires?
FastEagle
Taylors, SC
Posted: 05/28/12 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Defective tires?
There is a new post on the DRV forum reporting failures in two of those tires at the four and a half year mark. Treads were coming off. They replaced all four with Cooper Roadmasters (RM160) a 75 MPH tire. Here is a reference.
RM160
FastEagle
bigdon68
Posted: 05/28/12 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
I spoke with Michelin Customer Support when I bought our XTE2 tires. They specifically said the tire pressure for the XTE2 is 125 psi and that is what you should run.
Ours are doing fine. Enjoy the road this year.
bigdon68
retispcsi
Port Charlotte, Florida
Posted: 05/29/12 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Call a Michelin tire dealer or the company direct or e-mail. I had the same trouble with Commercial TA's. They will adjust the tires for you. You usually have to pay for mounting and balance.
joebedford
Jasper, Ontario
Posted: 05/29/12 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
Tires are 'funny'.
On my last truck the Goodyear Wranglers E's cracked within 2 years. Dealer pro-rated a new set (6) at 50 percent. They were so expensive I could have bought a different brand from a different dealer for the same $$. Anyway, the new Goodyears cracked again so I bit the bullet and put Michelins on it and there was no problem - traded the truck and the tires looked perfect.
I couldn't keep tires on the old TH - several blowouts, tread separations, sidewall bulges, etc. Problems with both ST and LT tires E rated. Then I put a set of G614 on it - end of problems. They looked almost new when I traded.
Now I have Michelins on the new truck and TowMaster on the new TH. They all look perfect but I only have 15000 miles on the TH (less on the TV). I plan to put G614s on the TH new winter.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
RAINEYTXX
Texxxas
Posted: 06/02/12 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Well, I'm going to tackle this tire issue next week. Going to start with DRV first and see if I can get anywhere with them. Any DRV owners have a good contact at the factory I can email and send pics?
