RV.Net Open Roads Forum: For a small solar install, what controller would you use?
 > For a small solar install, what controller would you use?
bka0721
Republic of Colorado
Posted: 05/27/12 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
I try to plan ahead and research things so I don’t make mistakes, which might cost money and time to correct. I am a serious extreme boondocker, not to be confused with the boondockers that dry camp in campgrounds. Most of my time is spent base boondocking in remote areas, as I explore the area via, hiking, motorcycle, kayaking. I plan for periods of 5 to 6+ weeks away from populated areas or replenishing. My current location is now, 7½ weeks and I have not done everything in this high desert. Due to some previous issues, I have learned to believe in redundancy. So I have many systems that can be switched over to another one, electric, propane, generators, transportation and now solar with solar. My original plan was to have a product I can park in the sun and have my living portion in the shade, which I have done. Now I am putting together a smaller system for my second solar system, much smaller and separate.
My plan is to install a second set of solar panel/s, for a watt amount up to and not exceeding 300 watts. As I found in my first group of solar panels (600 watt), meeting the “tipping” point of what my demand and solar output is an amazing point, when accomplished. So, my plan is to initially install a solar panel 100 to 150 watt (please feel free to recommend). I don’t wish to install a panel too large due to needs to; tilt, avoid shadows of surrounding permanent equipment, and snow load. Eventual build out would be anywhere from 200 to 300 watts. Cable/wire run would be less than 12 feet, from solar panel/s to battery.
If I understand correctly, an MPPT Controller is not as important for a smaller amp/watt system, as it would be for a larger system. I like my Tri-Metric 2025 RV Battery Monitor and would wish to use an additional one for my second system too. Pianotuna frequently recommends a Rogue Controller, but I have never noticed that he ever supplies a link to any particular one, so I am not able to determine whether that would be viable consideration. If he, or anyone else has a suggestion, I would certainly be interested.
The first ones I looked at were the;
Morningstar ProStar 30 Charge Controller with Meter
Blue Sky Energy Solar Boost 2512i & 2512iX
My question is;
“What Controller would best suit my needs for a proposed system, as I am proposing?”
(Cost, reliability and capabilities are my deciding factors)
Thanks for all help!
bryan
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
mena661
Posted: 05/27/12 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
MPPT is only needed for 24V and above panels. With you only needing 300W max, getting smaller 12V panels won't be an issue. People seem to like Morningstar around here but the Blue Sky is not a bad choice at all and their owners speak well of them. I don't have solar personally so I can't say what's best or not.
Trojan L16 6V's 740 Amp-hours
smkettner
Posted: 05/27/12 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Rogue just makes one controller that I know.
What controller do you have now?
675 watts solar
pianotuna
Regina, SK, Canada
Posted: 05/27/12 11:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hi bka,
Here is a link for you:
Rogue. They do only make one unit. If the Rogue is chosen, probably you won't need a 2nd Trimetric.
It may be cheaper to use a lower cost PWM controller (so long as it includes a three stage charger, and a temperature sensor), if the VOC on the panel is below 19 volts.
For your "back up" solar system I'd recommend 60 watts per 100 amp-hours of battery bank.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
cruz-in
Southern Maryland
Posted: 05/28/12 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
If you can get by with around 200 watts of solar, I really like the Morning star Sunsaver MPPT. Down the road if you need more , add a second Sunsaver MPPT...
wintersun
Monterey
Posted: 05/31/12 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
The Blue Sky Solar Boost 2000E is a good 2-stage plus equalization controller that handles up to 350W and 25A with 12v panels. It includes an integrated display which is an additional cost with most other controllers. All their Solar Booster controllers provide MPPT and all include a battery temp sensor.
pianotuna
Regina, SK, Canada
Posted: 05/31/12 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Hi wintersun,
The temperature sensor is a $35.00 "add on" to the Blue Sky price. That makes it more expensive than the more fully featured Rogue 3024 controller.
MrWizard
Traveling
Posted: 05/31/12 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
while MPPT is needed with higher voltage panels
I have tested my 17v+ panels with blue sky MPPT and xantrex pwm
and found that on a clear sunny day I get a higher total yield using the MPPT controller
because after 4hrs of good sun the Xantrex went into float mode and started trickle charge maintance at 13.2v instead of continuing to charge
this might be different depending on the pwm controller
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
