kerry4951
East Central Pennsylvania
Before and after pics of my pantry mod.......the way that the wood shelves are bolted into the frame makes the whole thing much more solid. The old metal racks just hung in place and did not help to support the framing. Its now much stronger plus provides a lot more storage.
Factory pantry rack with 4 wire baskets just removed from TC.
New wood shelves (5) with more capacity if desired
New mod installed back in TC
New mod tucked away. Only had to re-locate the bottom door latch to make things work.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
joe b.
Very nice work. Not only have you gained a lot of storage, the wood sure looks better, IMHO. Is the wood clear pine? Thanks for the photos.
joe b.
Stuart Florida
Formerly of Colorado and Alaska
Chevy 3500 DRW Dmax CC - Rockwood 8281 SS 5th Whl & 2008 Lance 845 TC
www.pajbcooper.com web site
Alaska Trip 2011 posted
Colo-Utah-Ariz 2012 trip posted
"Without challenge, adventure is impossible".
weymard
NORMANDY
For sure better looking, good job
Lance 815 2007
France, Normandy
Camper_Jeff_&_Kelli
Seattle
Now you can get the big cans of food in there and you added a shelf. That should be good for an extra day or two in the boonies.
Camper Jeff and Kelli's Blog!
kerry4951
joe b. wrote: Very nice work. Not only have you gained a lot of storage, the wood sure looks better, IMHO. Is the wood clear pine? Thanks for the photos.
Yes, used pine with 2 coats of polyurethane
pamvanw
southeastern pa
We need to do this to our Arctic Fox 30U. I see you have L brackets on the bottom 2 shelves, but have the top 3 just bolted to the slider frame. Any reason for this?
Pam
2012 Arctic Fox 30U
2012 GMC Sierra 3500 D/A
kerry4951
pamvanw wrote: We need to do this to our Arctic Fox 30U. I see you have L brackets on the bottom 2 shelves, but have the top 3 just bolted to the slider frame. Any reason for this?
Good observation....yes there is a reason for this. There is an internal catch release rod inside the frame. Running bolts thru the frame on the bottom 2 shelves interferes with the release rod. If you look closely you will see the two holes in the frame at the bottom shelf where I did try the standard bolt method but it didnt work. By using angle aluminum I was able to use self taping screws and miss interfering with the rod. The angle aluminum was only needed at those 2 locations.
Beefie
East Central Wisconsin
Very nice work, and way to reclaim space.
Beefie
pamvanw
southeastern pa
Just an update Kerry. We did your mod back in June and have been using it all season. Thanks for desiging it! We copied yours exactly and it's great!
kerry4951
pamvanw wrote: Just an update Kerry. We did your mod back in June and have been using it all season. Thanks for desiging it! We copied yours exactly and it's great!
Thats great. We have used ours a few times also and WOW!! what a difference. Im glad I could help a fellow AF owner out.
