RV.Net Open Roads Forum: Dealer Sold Me Overweight Truck Camper - Any legal options?
 > Dealer Sold Me Overweight Truck Camper - Any legal options?
Page of 21
tamaratrav
a
Posted: 05/27/12 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 07/21/12 01:04am by tamaratrav *
bka0721
Republic of Colorado
Posted: 05/27/12 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Actual weight and advertised weights are two different animals.
What camper do you have?
Age on your truck and prior use will impact the condition of the exisiting spring set up too.
You should have came here sooner or did your research before you bought, but you know that now. The best thing is you are asking for help now.
Welcome to the forum, lots of great people and a few grumps.
bryan
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
SWD
Land of Living Skies
Posted: 05/27/12 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Dealers only liabilities are for the camper.....its your responsibility for the truck. You'll spend an arm and a leg for the band-aid solutions on your truck. Trade it in for something that can handle your camper.
jmtandem
western nevada
Posted: 05/27/12 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
I made a mistake.
The solution is very simple. Don't mess with the Toyota any more. Just get a bigger more stout truck that will handle the camper. Done and you can then enjoy the camper of your choice.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
tamaratrav
a
Posted: 05/27/12 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
RWDIII
Casa Grande,AZ; Lakewood CO
Posted: 05/27/12 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Now you can go to all end of year sales,get a great deal on that F150HD
8200 GVW truck you have been wanting to get.Not bashing other brands,just dont know any other brands GVW.
Just found the website and since the website says your camper is for a 3/4 ton truck,I would now look for a F250 camper special
* This post was edited 05/27/12 03:15pm by RWDIII *
2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites, sat radio 50s on 5 or outlaw country
2013 Bronco 800
1200/1500 champion
Mostly Boondock
Boatycall
Tacoma, WA
Posted: 05/27/12 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
tamaratrav wrote:
2002 Toyota Tundra GVWR is 6,030.
The camper they sold me has a weight of 1,775 on the spec plate.
Fully loaded with occupants, actual weight is 7,700lbs
Hi!
First, welcome. Don't be afraid to ask questions here, especially on whatever truck you decide to get.
Here's what I don't get....
The GVWR is 6030.
Actual right now is 7700.
You're 1670lbs overweight.
You said The camper has an advertised dry weight of 1775.
The camper is now wet(loaded), not dry - add roughly 500lbs for one that size.
By my math, does that truck have a cargo capacity (after passengers) of ONLY 605lbs??
If that's true, no camper can go on that truck at all, not even a pop up. This explains why I don't recall ever seeing a Toy hauling a camper. They shouldn't have sold you a camper at all for that truck.
When shopping for another truck - MAKE SURE IT'S CAMPER CERTIFIED. I've owned Fords all my life. For Ford, it is a SPECIFIC option called the "Camper Package". On older Fords, it's most easily identified by looking at the rear axle. If you see a sway bar on the rear axle, it is likely rated to haul a camper - meaning there is also heavy duty springs under it. If not, it's likely not rated.
F250's and F350's have that option available, F150s do not. Don't get a half ton for that camper.
01 F350 DRW 4x4,Torklifts,SuperHitch,F550 Rear Suspension,Roadmaster ANTI-Sway Bar,Rancho 9000s
2012 AF 1150-4 Trojans,1.5kw Inverter,32" LCD,19" LCD,Basboard heat,Dish Tailgator,Ice maker,3 awnings,80a charge circuit,Polk Audio/Kenwood/Kicker sound system
tamaratrav
a
Posted: 05/27/12 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 07/21/12 01:05am by tamaratrav *
fordsooperdooty
Posted: 05/27/12 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
Ultimately, it's the buyer who is responsible for "due diligence" when making a purchase like that. "Never trust a salesman" was probably good advise when Henry Ford sold his first car.
Once the Camper was signed for by you and registered...the dealer has no responsibility. I would report him to the local BBB however...just because!
And the dealer should be aware that making deliberate misleading statements leading to injury, damages or death can result in jail time!
amxpress
Clayton, NC
Posted: 05/27/12 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
It's easy for someone to say, go buy a new truck.
If you can afford to do that, great. But don't waste your money on a 1/2 Ton, though. You should be able to find a good used 3/4 Ton or 1 Ton truck that can handle your TC.
If you can't afford to buy another truck, you might consider selling the TC.
I definately wouldn't suggest using your present truck for the TC as it is way overloaded and you would not be happy with the way it handles and drives with that TC in your bed.
Why not go back to the selling dealer and speak to the owner? Maybe he'll understand and help you out. Maybe, though I doubt it.
Good luck.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L denied parole! Yeah!
Page of 21
