RV.Net Open Roads Forum: YIKES!!! Purple Power Got me singing the blues!!!
 > YIKES!!! Purple Power Got me singing the blues!!!
plumber802
Vermont
Posted: 05/27/12 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hey fellow campers.I hope I didn't make a HUGE mistake by using Purple Power (aka Sodium Silica) to clean my rubber membrane roof.I used it in a 50/50 mix with water and scrubbed the roof with a brush to remove the grunge that had built up over the winter.The label said it was safe to use on rubber.Turns out though that when I rinsed it off it of course ran down the sides of the camper and over the windows and camper shell which created milky stains that I can't seem to get rid of.I tried wiping the windows with Windex and tried car wash soap but the streaks just won't go away.The aluminum skin of the camper has the stains as well.We were forced to look through ugly,milky windows all weekend.What can I do to get rid of these ugly streaks? I hope that an insurance claim can be avoided.Thanks for your valued advice.-Andy & Linda.
2008 SunnyBrook Edgewater 267RLE
2008 Silverado 2500 LTZ Duramax/Allison 4X4.
Equal-I-Zer 10,000# Hitch
Proud Member UA Local 693 Plumbers/Pipefitters
Joy
Henderson KY 42420
Posted: 05/27/12 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Vinegar, maybe? It cuts a lot of stuff.
See ya' down the road!
Don-SCPO USN Ret.Corpsman
Joy-Ret.Off.Mgr.
Maggie-Chihuahua
Chrissie-Chihuahua
Lucy-Jack/Rat
'06 42' Allegro Bus DP
'06 Saturn Vue
LIFE ISN'T ABOUT HOW TO SURVIVE THE STORM BUT HOW TO DANCE IN THE RAIN.
Homer
Northeast Indiana
Posted: 05/27/12 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
Try SNO BOL toilet cleaner on the glass portion. It worked for me in a similar mess. Not sure about the sides I think rubbing compound and elbow grease would be best on the painted surfaces.
fordsooperdooty
Posted: 05/27/12 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Probably not the best thing to use on an RV! Seriousily!
MSDS for Sodium Silicate-
"Slightly corrosive to corrosive in presence of steel, of aluminum, of zinc, of copper. Extremely hazardous in case of skin contact (corrosive, irritant, causes severe burns), or ingestion, or inhalation."
"Neutralize the residue with a dilute solution of acetic acid"...which is industrial full strength Vinegar. Try some White vinegar diluted with water to clean the residue on your windows and RV. You may have to re-wax afterwards.
Don't use anything on your roof except water, Murphy's oil Soap or diluted bleach for stains or mold.
Purple Power MSDS...
Jerrybo66
AZ
Posted: 05/27/12 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
plumber802
Thanks for the warning. Right or wrong I'm of the persuasion that don't try to out-think the engeneers of the roof. Clear water to rince off the desert dust is all I'll use..... IMO...
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
hallock5
Posted: 05/27/12 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
I actually spoke to a "detailer" at a campground last week and asked what he was using and he said "Purple Power", but he did confess he had to be very careful regarding it contacting the decals, windows, etc. and he also stated he used some other spray bottle with vinegar to wipe off any mistakes, so that may be the correct path. He said he was going back to using "Jolt", once done with the rig he was on.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
MitchF150
Washington, the State
Posted: 05/27/12 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
But I bet it cleaned up your roof really good!
I use the same car wash soap I use for the sides to clean the roof with..
Sure, my roof is not as white as it was when it was new, but it cleans up good enough for me and to where it does not leave the dreaded 'black streaks' down the sides of the trailer when it rains..
For the glass, I'd try solvents in stages to see what finally works.. Up to using MEK if necessary! I would hope that simple Mineral Spirits would do the job, but I have no idea what that stuff is you used...
Good luck!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
Francesca Knowles
Port Hadlock, Washington
Posted: 05/27/12 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
If your windows are tempered glass, the Purple Power may have "etched" them. If so, it may be that the etching can be polished off the glass with VERY FINE jeweler's rouge or something.
On edit
"Cerium oxide" is the polishing compound used for glass, not jeweler's rouge.
* This post was edited 05/27/12 05:51pm by Francesca Knowles *
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
IAMICHABOD
Sunny So Cal
Wow this is seriousily bad stuff and caustic I can only ask WHY???
Only water and mild soap on a rubber roof I thought everyone knew that........
2006 TIOGA 26Q CHEVY 6.0 VORTEC
Recycled El Monte RV Rental
Buying A Rental Class C
LadyRVer
Posted: 05/27/12 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have used Swirl and Scratch Remover on my RV windows... cleans them really good. I think it's made by Turtle Wax and probably bought it in WalMart. It gets the milky rubber streaks off from the roof. I put it on lightly and then wipe it off with a clean cloth.
