RV.Net Open Roads Forum: Class A Motorhomes: Genny problem
 > Genny problem
racer99
channahon
Posted: 05/27/12 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
My Generator stars fine from outside but won't crank over from inside any suggestions where to look first-once started from outside it runs fine & I can shut it down from inside--Rich
2000 Fleetwood Flair-30'-v10
Goldencrazy
madison wi
Posted: 05/27/12 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Are you priming it from inside as well as out?
enblethen
Moses Lake, WA
Posted: 05/27/12 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Look for a broken wire at the genset connector or behind the switch inside.
Onan? Check fuse on side of genset.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
racer99
channahon
Posted: 05/27/12 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Priming should not make a difference since it doesn't crank over from inside switch I THINK-If fuse was bad it wouldn't shut genny down-I will search for broken wire -bad ground and since it shuts genny down from inside I think switch is good-Rich
Tsalla Apopka
Crystal River, FL
Posted: 05/27/12 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Bad switch or loose wire. I'd pull the inside switch out of the panel and make a connection manually to see of the switch is bad or if it's the wire leading to the switch.
Denny & Karen
Florida's Beautiful "Nature Coast"
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Merlot - Sheltie rescue
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
PapPappy
Wilmington, NC
Posted: 05/27/12 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
X2
This way, if it starts, you know to replace the switch...and that wires are good.
Just because it will shut-down from inside, doesn't mean the switch is good.....
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
Dutch Star Don
Jonesboro, Arkansas
Posted: 05/27/12 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
My 98 Dutch Star does the same thing. Some times it works just fine,
but every now and then it won't start from inside.
So I'll be watching to see the answer.
Thanks
Don
Don Nall
1998 Newmar Dutch Star DSDP Motorhome, and one ever spoiled Pom named Cricket.
racer99
channahon
Posted: 05/27/12 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
OK fellow RVers check this out -We only had this MH for couple weeks so everything is a little new to us--Well since my hearing is very bad and this MH has the Genny at the rear of the MH it does start like it should-during the day the genny light inside isn't that bright so it was cranking but I couldn't hear it SORRY and quit laughing--Rich
Jim@HiTek
Gresham, OR, USA
Posted: 05/27/12 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
I had the exact same problem and spend a good amount of time checking the wiring and dash switch. No problems found.
Turned out that the connector inside the genset has really thin copper leads from the connector down to the circuit board of the control board. They are easily corroded and open circuit. The fix was to move the wire in the connector down to the next spot (it's empty), and to solder a jumper from terminal 3 to terminal 4 on the board. Terminal 4 isn't used in my rig so it was easy to do. Saved a few hundred. Naturally, I cleaned and coated all the the other leads while I was working on the control board.
Oh, wait. You're saying that you just couldn't hear it running? Well, then, just forget what I said.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
garry1p
Oklahoma
Posted: 05/27/12 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
OK no laugh but a big smile, you made my day.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
 > Genny problem
