RV.Net Open Roads Forum: Forum Technical Support: Posting Issues?
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Posting Issues?
Pete_k
Stantonville Tn
Posted: 05/27/12 07:31pm Link  |  Print  |  Notify Moderator
Having issues making post the last few days anyone else having these issues.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
sirdrakejr
Las Vegas, Nevada
Posted: 05/27/12 07:43pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to Forum Tech Support.
Frank
Eycom
32043
Not at all. What portal are you using?
RVn Full-time
pulsar
Lewisville, NC
Posted: 05/27/12 08:06pm Link  |  Print  |  Notify Moderator
The RV.Net portal has issues with certain characters. For example, it can't process percent symbols nor "smart" quotes, both single and double.
If you are having trouble posting through the RV.Net portal to the Open Roads Forum, you should try one of the others; for example, Woodall's
Tom
RoyB
King George, VA
Posted: 05/27/12 08:20pm Link  |  Print  |  Notify Moderator
I finally moved from RV.net to the Trailer Life Magazine portal. Something happened at RV.net about two weeks ago and I dont think they have really totally recovered from that.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Pete_k
Stantonville Tn
Posted: 05/28/12 03:05am Link  |  Print  |  Notify Moderator
I'm using the RV,net section. If its a short post without any pics or links it works. But add anything and it will not post?
Will try posting on one of the other links.
Pete
pulsar
Lewisville, NC
Posted: 05/28/12 05:17am Link  |  Print  |  Notify Moderator
Pete
If your picture file names contain a space, that would probably be changed to %20 by the host site and the RV.Net portal can't handle it.
Tom
joebedford
Jasper, Ontario
Posted: 05/29/12 08:49am Link  |  Print  |  Notify Moderator
trouble today
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
pulsar
Lewisville, NC
Posted: 05/29/12 09:22am Link  |  Print  |  Notify Moderator
Which portal? Have you tried the Woodall's portal? Link in one of the above posts. Also, a statement about a problem the RV.Net portal is having.
Tom
robanddi
Burton TX USA
Posted: 05/31/12 10:03pm Link  |  Print  |  Notify Moderator
I can't post with or without a link to my pictures. Very frustrating ...
Any fix in sight?????????????????????
Diann
P.S. Well this posted but not what I really wanted to add re animals on the Alcan!
Robert & Diann
2001 34' Foretravel U270
2004 Avalanche
Burton TX
 > Posting Issues?
