RV.Net Open Roads Forum: Fifth-Wheels: Balancing and shocks
 > Balancing and shocks
laknox
Arizona
Posted: 05/27/12 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
I wish like hell I'd had a handy video camera and hadn't been on a tight schedule today, or I could have shot a video that would have convinced every hardened no-balance/no-shock skeptic on here. We were heading up I-17 today when I came up on a guy towing a very new Gear Box TH, about a 25 footer. At first, I though he'd caught some trash underneath or the belly covering had come loose and I could see it flapping. As I got closer, I could see that it was the =axles= doing a major dance as he was driving about 65-70 mph down the road. I will bet that he's going to have flat-spotted tires and major suspension wear in short order. Had I been able to have a low angle of observation, I'd also be willing to bet that I could see daylight under the tires as they bounced off the pavement. Only makes sense to balance your wheels whenever you get new tires.
Lyle
1936 John Deere Model A
phillyg
Front Royal, VA
Posted: 05/28/12 06:07am Link  |  Quote  |  Print  |  Notify Moderator
I agree.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
JIMNLIN
out here
Posted: 05/28/12 06:27am Link  |  Quote  |  Print  |  Notify Moderator
So you could see at highway speeds the tires didn't have balancing weights on them already ??
And you could tell the tire hadn't split a belt or tread seperation issues ?? Your good
'97 Park Avanue 28' 5er 11200 gvwr two slides
Jim-Linda
Livingston, TX
Posted: 05/28/12 07:10am Link  |  Quote  |  Print  |  Notify Moderator
If it rotates, balance it.
Jim
Jim-Linda
Livingston, TX
Posted: 05/28/12 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Jim
Gooseneck
Waynesville, NC, USA
Posted: 05/28/12 07:26am Link  |  Quote  |  Print  |  Notify Moderator
99 times out of a 100 I would just let something like this fly by with no response. Then, there is that one that sets me off. The OP was making a sensible and justified comment based upon what he observed. Obviously, he did not stop the unit and inspect the wheels but made a reasonable assumption that most anyone of us would have made. Now, should I hit the "Post Message" button or not?
Gooseneck
2003 F350 4DR DRW w/7.3PSD 4WD
Upfitted/Updated Dutchmen 30' 5er
B.O. Plenty
Minnesota
Posted: 05/28/12 08:31am Link  |  Quote  |  Print  |  Notify Moderator
If a tire is out of balance it might shake a little but it shouldn't be bouncing off the ground. This is an indication of a much bigger problem, like an out of round tire or tread separation. This could be detected by trying to balance it but can only be cured by replacing the tire.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/28/12 08:47am Link  |  Quote  |  Print  |  Notify Moderator
The problem could also be exacerbated by axles possibly grossly out of alignment with the trailer and each other. That could further cause bad tire wear and tire failure, which could all have been going on at the same time.
Also, isn't towing a trailer at 70 mph illegal in AZ? I know it is here in CA. We have 55 mph towing speed limit here. Most trailer tires are speed limited to 45-65 mph (depending on size) by the tire manufacturer too.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
HamsHog
Fulltimer/ Palm Springs, CA
Posted: 05/28/12 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
Towing speed in Arizona is whatever is posted. I see vehicles from Arizona pulling trailers here doing 75+ and in the #1 & #2 lanes of 4 lanes on I-10 all the time..
Regards, Hamshog
2009 Silverado 2500HD EC/SB Dmax/Alli - SuperGlide 18K - Firestone Bags - 265/75R16's -
2010 Carri-Lite 36XTRM5 w/ Big Foot - Champion 4000W
2005 Harley-Davidson Road King Classic
2005 Jeep Wrangler Unlimited LJ
2007 Fleetwood Pegasus Ultralite M-180FQ
JIMNLIN
out here
Posted: 05/28/12 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
You gotta' do what you gotta' do. Guess you can also tell a tire has no weights on it at highway speeds.
When I see a loaded trailer with one tire jumping up and down off the pavement its certainly not because its not balanced correctly. As I and others mentioned something with the tire/wheel/suspension isn't right.
I've had a wheel do this on one of my equipment trailers not because it wasn't balanced but because six of the eight lugs had sheared and busted part of the wheels centers out. It destroyed the wheel and cracked the hub. The tire had a belt seperation with a huge bulge in the tread.
