RV.Net Open Roads Forum: General RVing Issues: teenage neices plugged toilet!!
 > teenage neices plugged toilet!!
Page of 6
shoreco
Long Island NY
Posted: 05/28/12 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Fill it 3/4 full with warm/hot water...
Drive around for a bit and let it slosh around...
You should be good after that...
2002 National Dolphin 5355
RedSunshine
Western Wisconsin
Posted: 05/28/12 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
is this thetford digester found at local walmart????
RedSunshine
Western Wisconsin
Posted: 05/28/12 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
I can't fill it. the tank is empty, the clog is high than that.. If I put anymor water in it the toilet will be over flowed..
whiskyrunner
Oconto Wisconsin
Posted: 05/28/12 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Just take a coat hanger, untwist it and poke around in the tank from up top and u will hook the toilet paper plug and break it up, been there, done that.
2000 Ford F250,4x4 diesel short box,Firestone airbags
2004 Terry Quantum 36ft fiver,4 slides
whiskyrunner
Oconto Wisconsin
Posted: 05/28/12 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
and from up top I mean the toilet seat area
ChopperBill
Colo
Posted: 05/28/12 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
Whats with these visitors from Venus? Mine goes through a roll a day at home. Told her to ration the paper in the fifth wheel or she will learn to deal with the after math. So far my threats have worked.
FunnyCamper
Southeastern
Posted: 05/28/12 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
that is funny and icky at the same time
that is one thing I have taught kiddo from day one. DON'T OVERLOAD. kids sure have a tendency to roll out the TP to the max.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/28/12 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
You can't just flush the toilet and stick a wire or snake down there when the valve opens and unplug it?
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
lanerd
Newport, OR
Posted: 05/28/12 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
RedSunshine wrote:
So over the weekend we had some rain so all my 2 kids and my three teeneage neices spent the day in my camper watching movies and gave the old throne a workout. I drained the tank when i left campground and when we got home my wife said there was gobs of toilet paper in the pipe from the toilet. So I go get 5 gallons of water and dump down the toilet. Now the problem is it is NOT draining. Has anyone had any experience with this?? Is there a chemicle one can use to break it down? I guess im leary about running a snake down it being it is all plastic.. Any suggestions??
When you say "it's not draining". Do you mean the toilet itself or the black tank?? If you put 5 gals of water down the toilet, I would then assume you mean the black tank is not draining. If this is the case, the solution is the one Bad99ram mentioned. Flush King. The force of the water pressure from the garden hose will force the paper back up into the tank and spreading it around so that it will come out the drain in smaller clumps. You might have to do this several times, but it will solve your problem.
Waiting for digesters to work, you'll probably be a year older before it's all clean. Running a snake down the toilet and hoping that you'll get the end of the snake to the drain hole will take a miracle!
You can get a Flush King knockoff at walmart.
Good Luck
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
sirdrakejr
Las Vegas, Nevada
Posted: 05/28/12 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from 5th wheels to Gen'l RVing Issues.
Frank
Page of 6
