somarmd
Upstate NY
Does anyone know if redmax pro 3 floor finish is still available anywhere? I tried finding it in Lowes both in a store and online and appears to be unavailable?
I hoped to use it to cover some peeling on my roof edges of MH.
Any thoughts appreciated, thanks.
07 Monaco LaPalma XL 34PDD
2002 Jeep Wrangler Sport Toad
Blue OX Tow Bars and Base Plate
Patriot Brake system
kcgaz
Scottsdale, Arizona
Found mine at Lowes in Scottsdale, AZ. Good luck.
God Bless,
Kevin & Tracy
1993 Fleetwood Tioga Arrow, 30', Ford 460...Still on the road!
My Blog
gbopp
The Keystone State
Go to Home Depot. I believe ZEP Step 3 floor finish is the same product as RMP 3. At least do a forum search, it's been discussed on prior posts.
somarmd
Upstate NY
Thank you I see it is the same product as ZEP at Home Depot.
Interesting enough none of the Lowes near me have the Red Max Pro?
Thanks again!
brirene
midwest
Lowe's has discontinued carrying the RMP. A few gallons are available now and then, but most are out. Seems like the ZEP is going to be the answer. I've still got about a 1/2 gallon, and will go to ZEP when its gone. Just finished the back cap this afternoon; looks great!
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
2bzy2c
California
Link
I did some investigation last December. Follow the link above for more information.
My advice is worth exactly what you paid for it.
michahicks
Waterford/Gaylord, Mi
Click on this link and enter your zip code to see if your local Lowes has it in stock. Every time I see one of these "they don't/aren't going to carry it anymore" posts, I check here. As of a few minutes ago, they do carry it at the store closest to me, and it's in stock.... for 6.39 a gallon.
http://www.lowes.com/pd_216595-531-RMPLM128_?PL=1&productId=3024836
1997 38' HR Endeavor, 275 Cat, Freightliner
2003 CR-V Toad, Blue Ox, Ready Brake
Obsolete
OnTheRoad
gbopp wrote: Go to Home Depot. I believe ZEP Step 3 floor finish is the same product as RMP 3. At least do a forum search, it's been discussed on prior posts.
That is what I used on mine. Did great!
National Tropi-Cal - 36'
with Banks PowerPak
