RV.Net Open Roads Forum: Tech Issues: Atwood water heater GC10A-4E
 > Atwood water heater GC10A-4E
Bucky Badger
Madison, WI
Posted: 05/28/12 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
So my electric side went out, as I read the Troubleshooting guide on page 35 it sounds like the only issues that would cause this would be the heating element, the thermostat, or the ECO...Tested and have power to and from the breaker.
http://bryantrv.com/docs2/docs/atwoodwaterheater.pdf
Anything else I should look at when I go back up to the camper?
It worked fine when I left it last weekend, might have been a little hotter than usual, but nothing this weekend
If it's the Thermostat or ECO is that's what behind the black sticky pad with brown and red wires...? It seemed very hard to pull it off any tips or tricks?
and yes the bypass valves are correct.
Fred & Jodie, dogs, Zoey & Mika
RIP Bella
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
ronmc
Brownsville Tx. 78526
Posted: 05/28/12 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
I had that heater. Check on back of heater,there is another switch. Mine had shorted out. I put in a wire nut.
Ron
2002 Kountry Star
2007 Honda CRV
Used Brake Buddy
Bucky Badger
Madison, WI
Posted: 05/29/12 05:02am Link  |  Quote  |  Print  |  Notify Moderator
txh for that. will check that also
Bucky Badger
Madison, WI
Posted: 05/29/12 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
hummm..nothing else
RLS7201
Some Where
Posted: 05/29/12 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Relay?
Texas Two Steppers
Beaumont, TX
Posted: 05/29/12 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Ground wire?
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
Bucky Badger
Madison, WI
Posted: 05/29/12 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Texas Two Steppers wrote:
Ground wire?
Grounds have been cleaned and reconnected
Texas Two Steppers
Beaumont, TX
Posted: 05/29/12 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
The adhesive around the black pad is just around the edges. A putty knife might help. New ECO and thermostat should be around $20. I haven't had to replace my element, but 3" angle iron will be a problem with mine. I guess I would have to pull the water heater out the front. Good luck.
A new sticky pad comes with the kit.
* This post was edited 05/29/12 05:59pm by Texas Two Steppers *
Bucky Badger
Madison, WI
Posted: 05/30/12 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
Thx for that
bobmacc
Ontario
Posted: 05/30/12 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
The ECO and the thermostat behind the black sticy foam are common for Gas or Electric operation and operate through the control board. You can rule them out if the heater operates on propane. Could very well be the electric element burnt out if it was not totally submersed or accidentally turned on over the Winter.
Bob
