RV.Net Open Roads Forum: Swap out a 13,500 btu for a15,000 btu air conditioner ?
 > Swap out a 13,500 btu for a15,000 btu air conditioner ?
Dixon Mark
Posted: 05/29/12 07:06pm Link  |  Print  |  Notify Moderator
Some are suggesting to add the second unit I did not want to have to run the wires and such plus my rig is a 30 amp power supply. And as for the wiring on domitic site it says the 13.5 and 15 BTU unit use the same size wire. And is there a big difference in brands? Is one brand better than the other?
Jim&Sharon
Arnold MD
Posted: 05/30/12 05:45am Link  |  Print  |  Notify Moderator
My 13.5 BTU Dometic, quit in Texas last year. It was during a spring heat spell of course.
I had it replaced it with a 15k BTU unit. It fits in the same hole, and uses the same circuit breaker as before (in my Wildcat).
But I can't say it cools any better than the 13.5k unit did when it worked.
I think the conclusion to draw from my swap, is that Texas is two AC country.
2006 Wildcat 27RL
2006 2500HD w/Allison/Duramax
KB3TXH
Retired JSO
Posted: 05/30/12 06:37am Link  |  Print  |  Notify Moderator
Like others, I don't believe you will see any difference.
We camped many years in the beach-side campground at Fort Clinch and Gamble Rogers state parks. If you have visited either, you know there is no shade. Our 15,000 BTU unit would keep the trailer in the 80's when outside temp was 95+. I broke down and installed a second 13,500 unit in the bedroom with it's own 20 amp breaker box and wiring system. We can still use 30 amp main service and use the additional 20 amp outlet for the front air.
kirbybear
Ft. Lauderdale Fl USA
Posted: 05/30/12 07:18am Link  |  Print  |  Notify Moderator
Have you cleaned the evaporator? I got 5 to 10 degrees more after a cleaning.
