RV.Net Open Roads Forum: General RVing Issues: The "ice cube" trick really works.......
 > The "ice cube" trick really works.......
Qcampers
Long Beach, California
Posted: 05/29/12 12:19pm Link  |  Print  |  Notify Moderator
I've read for years about putting ice cubes into your black tank to help break loose material stuck on sensors in black tank, but not until yesterday did I ever need to use it. Our black tank sensors have been unreliable for a while now, we have a back flush system and that usually does the trick. This time after an hour of trying...we filled it up 3/4 full and added all the ice we had left in freezer before hitting the road for home. When we got home we flushed and were "empty" once again. Good advice on here.....use it. Thanks
theoakman
Hereford, AZ, USA
Posted: 05/29/12 03:14pm Link  |  Print  |  Notify Moderator
I don't think ice cubes would last very long in our Arizona dry heat......
Cya l8r,
the oakman
funny, I don't remember being absent minded
Valkyriebush
Yuma/Port Townsend
Posted: 05/29/12 04:52pm Link  |  Print  |  Notify Moderator
Sorry. Double post. Not sure how to delete?
* This post was edited 05/29/12 05:04pm by Valkyriebush *
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
Valkyriebush
Yuma/Port Townsend
Posted: 05/29/12 04:51pm Link  |  Print  |  Notify Moderator
I quit looking at the BT guage a long time ago. I look down the hole. Accurate as can be.
jody h
Pride La.
Posted: 05/29/12 04:24pm Link  |  Print  |  Notify Moderator
I think just the water did the trick. That much water would take a lot of ice to keep from melting when it hits the water.
2006 Dodge Ram 1500 Megacab
2004 Flagstaff 8524RK
coolbreeze01
Redding, Ca
Posted: 05/29/12 04:59pm Link  |  Print  |  Notify Moderator
I haven't tried ice or salt. Sometimes they register correctly and sometimes they don't
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
rvten
Crossville,TN
Posted: 05/29/12 05:22pm Link  |  Print  |  Notify Moderator
Ice works best in a glass and Jack Daniels.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is no B+
MichDoc
Michigan
Posted: 05/29/12 05:26pm Link  |  Print  |  Notify Moderator
I put a bag of ice in the tank, along with a couple gallons of water, every week or so while on the road. It cleans the sensors, plus a lot of paper that adheres to the tank walls. I've thought too that the ice would melt quickly, but even in Texas when it was 90 out, when I stopped after several hours, there was still ice in the tank.
Bigfoot85
Washington
Posted: 05/30/12 10:26am Link  |  Print  |  Notify Moderator
I too have read about this for years ... now with your post, I'm going to give it a try.
Thanks!!
BlazingWest ... in an office with a view
Bigfoot 9.5
2004 Chevy 2500HD 6.0, 4.10 manual
Works2RV
Summerville, SC, USA
Posted: 05/30/12 01:01pm Link  |  Print  |  Notify Moderator
When we first bought our MH we had a Mount Poo in the black tank - read up on subject here amongst you experts and tried the ice trick. 55 gal tank - put in 5 gal of water and 4 bags of ice - drove around for an hour and then filled black tank and flushed. OOOW, the stuff that came out ( I use a clear section of drain pipe - let's me know for sure the flow has stopped - no surprises!! ). Do this once in awhile since then just to shake things up in there - seems to work - sensors work and have had no problems draining.
Some think it works, some don't - whatever blows up your skirt
1987 36' Beaver Marquis High Tech Wide body
3208T CAT, MT643 Allison in a Gillig MHA
Koni's & Toyo all around
FMCA, Good Sam
Jetta TDI
Marsha & Buck
