RV.Net Open Roads Forum: General RVing Issues: Does This TT Exist?
 > Does This TT Exist?
cm11599ps
Long Island
Posted: 05/29/12 03:48pm Link  |  Print  |  Notify Moderator
We are on the lookout for a certain TT. Here's what we would like if it exists.
1) Master bedroom up front.
2) Bunk beds in the back. We kind of like a set on each side of the TT for a total of 4 beds back there. I
3) Outdoor fridge. A sink and cabinets are a plus. A stove it not required.
4) Direct access to bathroom from outside.
Does an RV like this exist? I guess having only 3 beds in the back is OK if we have to make room for the outdoor kitchen but I'm pretty sure I saw TT's that had 4 beds and an outdoor kitchen.
downtheroad
Pacific Northwest
Posted: 05/29/12 04:02pm Link  |  Print  |  Notify Moderator
Check Jayco...they have a bazillion lines and floor plans.
Here is a start...
Jayco Link
Scroll down a check out Floorplan 29SQB
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
cm11599ps
Long Island
Posted: 05/29/12 04:05pm Link  |  Print  |  Notify Moderator
Thanks. That's pretty much what I want but it doesn't have outside bathroom access.
downtheroad
Pacific Northwest
Posted: 05/29/12 04:11pm Link  |  Print  |  Notify Moderator
Ok try this one....HERE...and scroll to Floorplan 314BDS
wittmeba
Virginia
Posted: 05/29/12 04:13pm Link  |  Print  |  Notify Moderator
Here are links to most major mfgs online:
http://gotnarcosis.com/brucewittmeier/technical/RVManufacturers.html
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
FoCoNoCo
Fort Collins, Colorado
Posted: 05/29/12 07:17pm Link  |  Print  |  Notify Moderator
There are a few Heartland North Trail models, Keystone Bullet Premier, as well as Prime Time Tracer and LaCrosse models. Also K-Z has some similar. Most of these only have 3 bunks due to the outdoor kitchen, but some have either a trundle bed or a flip open sofa. Jayco also has a White Hawk model that is similar. Most of these models have in excess of 8500 lb GVWR, with the Prime Times at about 9600 lbs.
fordsooperdooty
Posted: 05/29/12 07:21pm Link  |  Print  |  Notify Moderator
I don't know how big you can go for your "dream trailer"...but looky here! Hope you're sitting down!
Jayco White Hawk 31DSLB...the newest line that Jayco has, engineered from the ground up, to be light weight, aerodynamic, tows great because of the "wide stance axles", yet is still has a substantial steel chassis and a lot of standard equipment.
And it has Jaycos' high pressure vacuum laminated construction that is 10x less likely to delaminate than other types,
And the 2 year warranty from a family owned builder in business for 43 years...they sell 2 of the #1 selling Trailers in North America for almost 8 years.
*"Master queen walk around bedroom up front?" Oh yeah.
*Outside kitchen? Check! Has it's own seperate awning, stove and sink.
*Outdoor Refrigerator is standard....Check!
*2nd door at rear restroom by bunk area? Yep!
*3 bunk beds in rear PLUS a sofa bed! Yes!
*Bunkhouse wardrobe slide out...Uh-Huh!
34'11" but only 8200 lbs GVWR. 45 gallons each Fresh Water and Grey (Nice!), huge "U" Dinette and another sofa bed in slideout. Sleeps 6 to 10!
AND IT'S REAL PURDY TOO!
Good luck!
JayWalker2009
I'm not really a
Posted: 05/29/12 10:29pm Link  |  Print  |  Notify Moderator
This is likely very doable, but we don't know what you can tow or pay. That will way in heavily.
502_Jimmy
Richmond VA
Posted: 05/30/12 08:22am Link  |  Print  |  Notify Moderator
Depending on what you can tow... Primetime has several models that fit the bill...
LaCrosse 318BHS
Tracer 3150BHD
Avenger 32BHS
I have the LaCrosse and love mine..
John
netomh
Far North Dallas
Posted: 05/30/12 09:45am Link  |  Print  |  Notify Moderator
Mine has what you're looking for, but as others have said, it depends on what you're towing with - mine isn't particularly 1/2-ton friendly.
Keystone Sprinter 311BHS with the trundle. Listed dry hitch weight is a pipe dream - mine was 1020# off the lot, running about 1150# loaded.
Several others have the same floorplan, some are considerably lighter.
2010 Ram 2500HD Crew ST, 6.7L, 68RFE, bone stock.
2010 Keystone Sprinter 311BHS
