RV.Net Open Roads Forum: Tow Vehicles: filling with diesel
Search only in Tow Vehicles
 > filling with diesel
45Ricochet
North Idaho
Posted: 05/29/12 08:05pm Link  |  Print  |  Notify Moderator
naturist wrote:
Given the propensity for diesel fuel to foam. You might want to consider listening closely for the sound of the fuel/foam starting to climb the filler neck.
X2
That is why MPG numbers are all over the board on this forum. Unless you wait for the foam to dissipate and fill to the top of neck each time your MPG will be different. Unless your IB516
I suspect your gallons per tank reading is a safety feature margin. Don't want to run a diesel out of fuel, especially a CP4 HPFP
Titan makes a replacement tank for your truck which adds IIRC 15 more gallons. 26 gallons is just to small IMO.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
path1
seattle
Posted: 05/29/12 08:07pm Link  |  Print  |  Notify Moderator
That is the "burp" that says I'm full.
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
F105
Keller Texas
Posted: 05/29/12 08:14pm Link  |  Print  |  Notify Moderator
raleighdogguy wrote:
I've got a 2012 super duty 6.7. Every time I fill it up I get a little fountain of diesel spilling out before the pump shuts off. I've tried pumps with narrow nosels and wide ones. I've tried putting the pumps all the way on and only one-click on. I can't quite figure it out.
Also, my truck supposedly has a 26 gallon tank, but I can only account for 23 of those gallons. I've never had a refuel take more than 20.5 gallons, and I typically refuel with 50 or so miles left until empty (which equates to 3 gallons). I'm not sure if that's related to the fuel spilling issue or not.
This is my first diesel, so I may be doing something wrong. I had just assumed that diesel pumps would have the same auto-shutoff as gas pumps. Am I wrong?
Thanks!
I have a 2012 Ram 3/4 ton with the Cummins 6.7L engine and it has a 35 gallon tank. Also as someone else posted I learned not to pull up to the big rig pump islands as their pump flow is much greater that what ny little Ram can handle.
doublenot7
Clear Lake, Texas
Posted: 05/29/12 08:16pm Link  |  Print  |  Notify Moderator
I also have the '11 F250 6.7L and I do not get overfill at all upon visiting my usual fuel stops. I have had overfill on a few rare occasions while traveling (not truck pumps). All pumps are not equal I guess.
NEVER run down to empty as others have said. I think the closest I have gotten is down to 75 MTE. You don't crank repeatedly either to get the fuel circulated, just turn the ignition part way, pause, repeat a few times (3-6 ? I forget). Same as when you change the fuel filters and have to re-prime.
halibutman214
Oregon
Posted: 05/29/12 08:19pm Link  |  Print  |  Notify Moderator
And now if you can believe it, back to the question... No your not wrong, they do have the same shut-off and while I have seen this happen occasionally I have never had it happen to me even when the nozzle is fully compressed. I saw my sons older 1998 Ford do it maybe once or twice but he was trying to top it off. Whether by design or something else I would guess you have some sort of vent issue.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
path1
seattle
Posted: 05/29/12 11:09pm Link  |  Print  |  Notify Moderator
Must say on long trips I'm guilty of topping off, I get as much will fit into tank and filler spout. No problem of leaking because you're burning it off and within 20 miles its used a gallon. And I fill up around half because the there is always a chance you'll get bad fuel and you'll now where you got it from if motor starts acting up after you went thru 1/2 tank and no problems and the bad stuff will be delutied. And besides my bladder won't go much longet then 3 hours....
I do not top off around home because diesel does swell up with temp and it is not to good for your driveway, or wife telling you about it.
sc3283
St Louis
Posted: 05/29/12 11:11pm Link  |  Print  |  Notify Moderator
o4 chevy here and it will always burp fuel before the pump kicks off. I nurse it so it won't do that. i always fill slow towards the end to get fuel visible in the neck. From the pump kick off to actually full is almost 3 gallons due to the foaming of diesel. Doing this I get accurate MPG calculations as well
04 D-Max Crew Dually
96 Monaco Dynasty 36'
NewsW
US
Posted: 05/30/12 04:37am Link  |  Print  |  Notify Moderator
Since it is under warranty, why don't you take the dealer service writer for a fill n' see for himself?
1jeep
acushnet ma.
Posted: 05/30/12 07:55am Link  |  Print  |  Notify Moderator
Short bed has a small tank, i find it hard to believe ford couldnt have fit at least a 30 under the short bed.
Anyway i can hear a gurgle right before mine is full, i have the long bed some i can tell tell you if that is related to the tank being bigger.
2011 F250 CC LB, 6.7 urine injection
2007 keystone Outback Sydney 32BHDS
2009 HD Ultra CVO
2013 CanAm Outlander 1000
1963 Wife..no mods
christopherglenn
a little over an hour from Yosemite
Posted: 05/30/12 10:18pm Link  |  Print  |  Notify Moderator
I have a titan 62 in my truck. Most I have ever put in it is 55. After the pump clicks off, I "top off" about another 10 gallons.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
