keepingthelightson
Santa Clarita, Ca
Hopefully I can get some help here. 2005 CAT C7. I changed my fuel/water separator, primed and now it will not start. It ran for a few seconds then slowly stopped running. I tryed starting fluid and still no luck. I am concerned the filter on the engine may need to be changed as well (only one year old). Could I have gotten some bad fuel and plugged the engine fuel filter? Brett are you out there?
Thanks!
05 Tiffin Phaeton 40 QDH w/4 slides
CAT C7 350+ HP MP-8, Aero Muffler, AFE Filter
06 HHR LT Toad
Ready Brute Elite
Tom/Barb
Oak Harbor
Sounds like air in the system.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
keepingthelightson
Santa Clarita, Ca
After reading another post that Brett Wolfe wrote, I had the nose down creating an air bubble. So now I have the batteries charging and the MH in the driveway and I can't move it. How do I (if this is the problem) get rid of the air issue? No primer pump on the engine.
BigSkyBob
Helena, Montana
Can't you turn on the ignition for 20 seconds then off to run the lift pump. Do this several times and it should force the air out of the filter and the rest of the system. I'd probably do this 8 or 10 times to be sure then try to start the engine.
2008 Monaco Camelot 40PDQ, 4 slides, 2012 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 7200 GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
Big Katuna
Deland, FL
You can buy a manual pump and add it to the filter mount. Did you fill the filter with fuel?
My Kharma ran over my Dogma.
pianotuna
Regina, SK, Canada
Hi,
I know little about diesels--but mine had a "bleed valve". It was very similar to a dill and schraeder tire valve. One person depressed the valve and the other cranked the engine over. When the person holding valve saw diesel--then it would start.
Best of luck with this!
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
keepingthelightson
Santa Clarita, Ca
Big Katuna wrote: You can buy a manual pump and add it to the filter mount. Did you fill the filter with fuel?
Yes, filled the filter first. Last time it worked fine.
SCVJeff
Santa Clarita, CA.
I got nothin', but as you can see we're neighbors. So holler if you need additional help.
Jeff - WA6EQU
lfeather
Titusville, FL
I've heard of pressurizing the fuel tank with a compressor, air hose and a rag? Probably don't want/need much pressure (10 PSI?)
Larry, Debbie, Tiki and Tomi
USAF Retired
2003 36' Country Coach Allure #30856
2008 Tacoma Towed
SMI Air Force One toad brake
Wild One
babylon new york
pianotuna wrote: Hi,
Does sound like you are air bound . Do like he says and look for a bleeder valve , if no valve you may have to loosen each injector until you see fuel come out of each one.
95 Holiday Rambler Endeavor
