RV.Net Open Roads Forum: General RVing Issues: Why steel valves with new tires?
 > Why steel valves with new tires?
TOOBOLD
CALI
Posted: 05/29/12 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
I've learned a lot on the boards, but don't know what this is all about. We are getting new tire on Thursday and don't know whether I should have them put steel valves on?
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 05/29/12 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
What are you getting new tire's on , if mh yes you should have steel stems for pressure, rubber stems are for cars????
1998 34' Newmar Mountain Aire,210 Cummins Puller, 542 Allison 4 speed, BD Performance Exhaust Brake, BD Torque Convertor, Hendrickson Air suspension, 4 wheel disc brakes. 4-120 Watt 2-80 Watt Kyocera panels 8-T105s Toad 2003 VW Jetta TDI.
TOOBOLD
CALI
Posted: 05/29/12 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
We are getting it on our GVWR 10,700 lb 5th wheel
dave54
Northeast CA.
Posted: 05/29/12 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
rubber eventually cracks, breaks down, gets weak, etc. Steel lasts longer so less likely to a get a slow air leak through the stem.
Log off and go camping!
mike4947
N. Syracuse, NY
The "rubber stems" are rated for a maximum of 60 PSI and it is recommended they not be used over 50 psi.
High pressure valve stems come in several varieties. Some are rubber coated and do look similar to the low pressure variety. We always ask to see the packaging for info if they come out with one that looks like a low pressure one.
One thing to remember is even the "steel ones" have a rubber seal to seal the stem to the rim.
And no matter what type you have, replace them when you change tires as the rubber dry rots as fast if not faster than the tire.
As an FYI for folks with duals they make extended all in one piece valve stems so you don't have add any extenders. Which we've had trouble with over the years. Whether they are the pressure or airless type. We get ours at tire service centers that specialize in heavy trucks.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
Parrothead Mike
SW Michigan
Posted: 05/29/12 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
The rubber valve stems can deteriorate over time, especially with the sun and variations in the weather. This happened to me and caused two separate flats. Thankfully we didn't have any serious problems with those flats and now I always get metal collars on the valve stems.
2002 Chevy 2500HD Duramax - 2001 25' Cardinal LXDS
16K Huskey EZ Roller Hitch - EU2000i Honda Generator
path1
seattle
Posted: 05/29/12 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
The bolts that hold them tight and in came loose one time on one tire. Lock tight solved that. No other complaints.
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
smkettner
Posted: 05/29/12 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
A bunch of car stems a few years ago were defective and cracked within 6 months. Some might even still be around to get installed. If you don't want metal get some high pressure snap in stems. These are good to at lease 80 psi "E" tires.
http://www.tireresources.com/index.php?p=product&id=1886
675 watts solar
NorthernLimits
Michigan
Posted: 05/29/12 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
As said, most all rubber ones are for lower pressures. The metal ones are considered "high pressure".
I had all new tires put on my dually but the bastards at the Goodyear store here in Sault Sainte Marie Michigan put low pressure stems on the inside tires in the rear. I didn't catch it.
I blew one out about half way to florida and ruined the tire driving on it flat. Didn't know it went flat. Stan Caruso, the owner of the Goodyear place, wouldn't reimburse me for the tire I had to buy on a Sunday in Tennessee even though I had the receipt and the blown out valve stem and the ruined tire when I returned.
So save yourself the trouble and go with the metal ones.
Tom&Dale
Manhattan Beach, CA
Posted: 05/29/12 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
I had a flat on my pickups right rear Michelin when towing through Salt Lake City that was traced to the valve stem. Have since replaced all (trailer and truck) valve stems with steel. Not that expensive considering the effort to fix on the side of the road.
02 Dodge 2500 CTD, Edge EZ, Goerend transmission (3.55 axle ratio), BrakeSmart, BD exhaust brake, Firestone Ride-Rite air bags, Husky 16K hitch & towing our 05 Americana LC30/31 RL
