weeeee
West Chicago
How do you route the trailer plug wiring from the truck to the trailer and keep the excess length from being pinched by the WD hitch and sway bar?
The reason I ask is because I recently had the wire get pinched and short cause the trailer brakes to keep locking up. I had to rewire on the side of the rode to fix.
Just looking for some wisdom as I am completely new at this.
Desert Captain
Tucson
Three loose wraps around the left side trunnion bar of my Reese WDH takes up the excess but leaves enough slack for me to cut all the way, (90 degrees), without putting tension on the 7 pin plug. I only have one anti sway bar and it is on the right side.
Boharris
Olive Branch, Mississippi
Had the same problem with a horse trailer once and I cut one end and ran mine through a long piece of garden hose.
1975 Dodge Sportsman 20ft Open Road.
Jack_Diane_Freedom
Milton Ontario Canada
Couple of wraps around the front trailer jack.
Terryallan
Foothills NC
I just hang mine from the other side,
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
dupreet
High Point, NC
I have it ball-bungee'ed to the jack post. I can slide the cable as needed.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
2Macs
Indianapolis, IN
I use a pin with a wire locking loop pinned through the hitch pin lock hole. Then I run the trailer wire throught the loop. It keeps the trailer wire on top of the hitch and allows movement when driving and making turns.
weeeee
West Chicago
Thanks for all the replies, one of these should work for me.
BradinOhio
Akron, Ohio
Jack_Diane_Freedom wrote: Couple of wraps around the front trailer jack.
X2. Never had any issues.
Brad ('68), Sandy ('71), Amber (shephard), Niko (shiba inu)
'12 F-150 XLT SuperCrew 4x4 Ecoboost with MaxTow
'12 Flagstaff V-Lite 30WRKSS
'10 Keystone Passport UL 245RB (prior - retired 6/2012)
'07 Rockwood Roo 21SS (prior)
Allegheny N F Camper
Pennsylvania
I route mine thru the safty clip on the hitch pin.
