RV.Net Open Roads Forum: Class A Motorhomes: Gen-turi generator exhuast system
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Gen-turi generator exhuast system
Page of 5
Weathertodd221
FL
Posted: 05/30/12 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
mike4947 wrote:
I'd like to add we've had several folks report that they have had CO fumes in their RV when parked alone boondocking when running their genset. Depending on how and where the exhaust is located fumes can collect under the RV and even slight breezes can cause a concentration of CO in and around an RV.
Personally I won't stay in or near an RV without a Genturi put the fumes above the RV; and we have measured noise levels without the Genturi and with the Genturi pointed up the sound levels were decreased.
Ive seen diesels with the genny exhaust exit near the front tire... then the occupants had the slide out with the window open not 3' away.
Diplomat Don
Moorpark, Ca
Posted: 05/31/12 12:13am Link  |  Quote  |  Print  |  Notify Moderator
"John Wayne"....very good point about where the air is drawn from.
The Genturi is a very well made product and is onsale at Camping World as stated above for $139.00. I like to build my own stuff, but as I said it's well made and comes with a carrying bag. Many have built their own, but it is one of the items I believe you should buy form the manufacturer. There just isn't enough savings in the long run.
I will add that I didn't like the unfinished end that you must add to your generator tail pipe. I welded on a nut/bolt behind their tailpipe mounting tip that allows me to attach a chrome tip that twists on and off.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
Tarheel 2
North Carolina
Posted: 05/31/12 04:38am Link  |  Quote  |  Print  |  Notify Moderator
wny_pat wrote:
Living On wrote:
Lots of people swear by them. Cummins/Onan advises not to use one. It will kill the warranty due to "excessive backpressure".
If it is hooked up properly, there should not be any excessive backpressure to bother anything, but if you connect it solidly to the generator exhaust pipe, you will have effectively changed the manufacture specification pressure of the exhaust system. Never have heard of anyone getting their warranty killed because of using a Gen-turi.
I actually bought my Gen-turi from Cummins in Greensboro while getting service work done on my engine. Wouldn't have thought they would have sold them if there was a warranty issue.
Tarheel
Dutch_12078
Great Sacandaga Lake, NY
Posted: 05/31/12 06:06am Link  |  Quote  |  Print  |  Notify Moderator
Living On wrote:
Lots of people swear by them. Cummins/Onan advises not to use one. It will kill the warranty due to "excessive backpressure". Search on Onan site for this. Also it dumps the fumes above the roof line where your a/c system can draw these into the MH if you have any seals that are old etc.
A properly installed Gen-turi does not create any additional back pressure. The roof top A/C is a closed system that does not draw any outside air into the RV. The inside air is cooled and recirculated, while the outside air is used to dissipate the extracted heat to the outside, the same way a refrigerator works.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 05/31/12 06:11am Link  |  Quote  |  Print  |  Notify Moderator
I agree with Dutch. I use a Gen-Turi all the time while at the track and it works terrific. One thing that I do is put my roof vent fans on low; this allows me to keep the vents open when the gunny is on and the ac is off.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
Gordysvette
Minnesota
Posted: 05/31/12 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone use them on your Aqua Hot system ?
Gordy
mph_medic
Southaven, MS (Outside Memphis, TN)
Posted: 05/31/12 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Here is my answer to the exhuast problem..
Clicky link.
You can spend $130+ or make your own... To each his own..
Never do anything you wouldn't want to explain to the Paramedics...
1993 Damon Frontier Flyer
Living On
Where Ever
Posted: 05/31/12 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Just go to the Cummins/Onan website and review their warranty. They have a full section devoted to why they can void the warranty with this type of exhaust extension. If you have burn't valves and the wrong dealer sees your hook-up, he will only approve what the manufacturer approves of. And yes if all the exhaust has to slip stream up the pipe, then there IS additional backpressure for the engine to pump that exhaust up the pipe.
Don't kill the messenger. Look it up.
Good Luck
* This post was edited 05/31/12 07:12am by Living On *
jauguston
Bellingham, WA
Posted: 05/31/12 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Live on,
Have you ever looked at a Genturi? Your description of the bad things it can cause leads one to believe you have never seen one. There is NO exhaust restriction.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
JC2
Mo
Posted: 05/31/12 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Amazon.com has the Genturi on sale for $103.00.
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
Page of 5
