smkettner
If you camp amoung people in tents pass on the gen and get some solar.
There are other ways to make, use, conserve power then just burning a bunch of gasoline.
675 watts solar
SolidAxleDurango
OK, USA
If you follow the rules (ie hours of operation, spark arrestor installed, DB limit if applicable).... I don't give a damn if they hate me. I'm not there to make friends. I'm there to do what I want to do.
If THEY go to a campground and don't like it when other people do things they're allowed to do, it's their damn problem. Not mine.
Why stop with generators? Why not ask the question, "If I let my kids ride their bikes, will people hate me?".... "If I walk my dog..."
Go camp. Follow the rules. Enjoy yourself.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
tvfrfireman
Portland, Or
larry barnhart wrote: If the new MS has an inverter would that work for night time needs. If the MS has a surge protector built in a 2000 honda might not enter the coach. I had this problem but solved it very easy by using a battery charger and using the 1000 honda to power the charger and used the inverter during the evening. Not good if the AC is needed but works great for us when we used it for boondocking.
chevman Larry: I was just replying to the other guys post that the generator should only be run for cooling. I was making the point that some of use use more amp hours in a 24 hr period due to health equipment. My cpap can be used with an inverter but I also have a 12 volt adapter cord and can plug into a round 12 volt receptical. I still end up using about 60 amp hours a night and have to charge the batteries a little longer. Are you telling me that a built in surge protector keeps you from charging your batteries?
SolidAxleDurango
OK, USA
DrBaker wrote: I don't see how this could be very difficult.
If you want to use a generator you should only use it in an area that permits generator use. You should also follow any time of day restrictions too. If you do not want to be near a generator you should only stay at areas that do not permit generator use.
Neither side is wrong or right. If you have a strong preference just pick somewhere that matches your desires.
Agree!!!
larry barnhart
wenatchee. wa usa
tvfrfireman wrote: larry barnhart wrote: If the new MS has an inverter would that work for night time needs. If the MS has a surge protector built in a 2000 honda might not enter the coach. I had this problem but solved it very easy by using a battery charger and using the 1000 honda to power the charger and used the inverter during the evening. Not good if the AC is needed but works great for us when we used it for boondocking.
The surge protector stops low power from entering the rv. So to charge our 4 12 volt batteries I plug into the front of the alpenlite the same as when towing. I have the plug that matches up with the trailer installed on the 15 amp battery charger. This allows the 4 12 volt batteries to charge. I tried a 2000 honda to connect to the normal way to get power and the honda shut off. Low power. I only say this because it works very well. If we were to be in a very low campground and the surge protector wouldn't allow power to enter I use a cord from the power from the park to run the 15 amp charger and use the 2000 watt inverter for electricity. I have done this also and it works very well. I have not been in a very poor rv park with low power for a while but have many times in our early years of winter travels. Just information.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Bit Bucket
Brookings, Oregon
SolidAxleDurango wrote: DrBaker wrote: I don't see how this could be very difficult.
Agree!!!
x2!!!!
For complete solitude, dry camp where no other people are!
I don't impose my definition of camping on others and expect the same in return!
mowermech
Billings, MT
SolidAxleDurango wrote: If you follow the rules (ie hours of operation, spark arrestor installed, DB limit if applicable).... I don't give a damn if they hate me. I'm not there to make friends. I'm there to do what I want to do.
My sentiments exactly!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Locky
West Michigan
No matter what you will not please everybody. If you do use one just use it respectfully. If somebody has a problem with it just take them out and show them where the bear ****s in the woods.
jetboater454
Camping or home
Was in a Flying J once with our gen running,along with 4 or 5 others that had theirs running.A big MH came and parked between us and asked us to turn off our gens--said it was not allowed in the parking lot as it was a quiet place to sleep.We told him of no such rule.Funny thing was he moved back into the truck parking area.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
korbe
Northern California
I have noticed quite a few posts stating, "if it's within the rules....., it's okay."
Why do you need a rule in place to be considerate.
The reason campgrounds created a rule indicating quiet times, is because people were not considerate and thus, the rule.
That inconsiderate attitude will eventually bring in a new "rule", effecting when and if generators can be used.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
