RV.Net Open Roads Forum: Tow Vehicles: Which Truck? 7.3L or Duramax
Search only in Tow Vehicles
 > Which Truck? 7.3L or Duramax
Page of 9
CND SuperCrew
SK, Canada
Posted: 05/31/12 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
You can go over to Dieselplace.com and in one of the forum areas leave the VIN and in a short time one of the moderators will reply with a complete hx of the truck. That was my deciding factor when I bought mine.
Ron, Lori and Autumn
TV 2012 F150 loaded XLT EB SuperCrew 7700GVWR Maxtow 6.5'
TT 2008 Jayflight G2 23FB/ Equal-i-zer WD
2013 Colorado bound
2012- 4000km, 28 nights for the season
2011- OR & CA done, 6800km in 3 weeks
45Ricochet
North Idaho
Posted: 05/31/12 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Someone mentioned the "pump rub" and I'm not positive which years were affected but something to put on the todo list.
Link
Although the lift kits certainly look cool, if you plan on pullin a 5th wheel RV most of the time your going to run into rail clearance issues with them.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
GrandAZ
Indiana / Arizona
Posted: 05/31/12 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
NewsW wrote:
GrandAZ wrote:
Ok, so I see the 06 D-Max is highly recommended. Now take a look at the info and let me know if this changes anything....
- 2006 2500hd Duramax with 117K miles:
-- Stock
- 2003 2500hd Duramax with 104K miles:
-- Stock
- 2002 Ford F250 7.3L with 78K miles:
-- 6" lift and 4 linked, coilover, front end on King remote reservoir shocks, Garrett GTP38R, 4" MBRP exhaust, Gauges, Performance valve body, Diesel Innovations Chip, GPS, Stereo, TV (all the interior bells and whistles)
- 2000 Ford F350 7.3L with 123K miles:
-- New Shocks, New Brakes, New tires, Gauges, 48 Gal Transferflow Tank
Need a more comprehensive examination than that to uncover mods, tuners, etc.
I'm not new to the diesel world by any means, and I am pretty good at recognizing the stock from the not. I also take a code reader with me to everything I look at, I know it will not pick out and identify tunes, but still better than nothing.
What are you suggesting? Your saying something different needs to be done but then leaving me hanging with no solution or suggestion....
2006 D/A 2500HD: SRW, CC, SB, 4x4
Kip81
utah
Posted: 05/31/12 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
IMO the 02 7.3 is the only one that I would consider. They rest have to many miles on them for me to spend that kind of money.
glamisorbust
Arizona
Posted: 05/31/12 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hands down, 06 LBZ. This is as good as it gets for reliability and mileage. I bought mine new 5 years ago, and now I have 90k miles on it. Never been stranded, never had any serious problems. I've had the ISS, which is the intermediate steering shaft replaced twice under warranty. Seems to be fine now. The allison trans. is the best thing since sliced bread. If this truck is bone stock you just found a gem. The allison can only hold about 100hp more than stock without grenading. You'll love the d-max in stock form. Plenty of power, and very, very quiet. Occasionally you might be able to hear the turbo winding up, but you can't tell you are driving a diesel most of the time. The 7.3 is a great engine but the trannies are another story. Anything lifted or with larger tires I would stay away from. These trucks are for pulling, and lifting them completely destroys the towing ability and usefulness of the truck. I would buy my '07 classic again in a heartbeat, this truck is not for sale!
GrandAZ
Indiana / Arizona
Posted: 05/31/12 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
The 02 7.3 is the most expensive out of them all because of the mods it has....
CND SuperCrew
SK, Canada
Posted: 05/31/12 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Dmax Pump rub
gmcsmoke
Butler
Posted: 05/31/12 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
A code reader won't recognize a tuned ECM you'll need a tech II. Before GM woke up to the fact in '07 and started storing data in multiple places a HP/TQ reading from the ECM/TCM will tell you without a doubt whether it was tuned or not.
A 1/2 shop charge and a tech II from the dealer will put it to rest.
NewsW
US
Posted: 05/31/12 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
GrandAZ wrote:
-- Stock
-- Stock
Don't know when the break year is for GM when they introduced a lot more functions on the computers. On the Fords it is 2005 model year.
But there should be a few dealer tech accessible tricks that will tell you if it has ever had a tuner.
e.g. there should be a reading for maximum torque the transmission measured.
Also a way to know how many times the stored values have been written to and --- how many were not done by the dealer and hence have to be tweaks.
Not at the dealer, but at the manufacturer's level, there is no hiding from them that a vehicle have ever used a tuner.
Engineer9860
Eagle Scout dad
Posted: 05/31/12 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
One more reason to consider the '06 DMax:
Click Here
In Memoriam: Liberty Belle
Page of 9
