RV.Net Open Roads Forum: Tow Vehicles: Which Truck? 7.3L or Duramax
Search only in Tow Vehicles
 > Which Truck? 7.3L or Duramax
Page of 9
bmanning
Phoenix, AZ
Posted: 06/01/12 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
GrandAZ wrote:
GrandAZ wrote:
I am going to look at a 2001 F250 7.3 tonight and my mechanic is going with me.
2001 F250 7.3L Lariat - Crew Cab Long Bed with 111K miles:
- Air bags, Fox shocks, Built heavy duty transmission, Gauges, Back up sensors, 4" Exhaust.
Hopefully everything checks out! I will post pics as soon as I make a decision on a truck.
Well just got back from looking at this one, my mechanic gave me the thumbs down but boy I sure am glad he was there! Saved me a lot of headaches that I would have been walking into
On to look at a few D-Max's in the morning.....the saga continues.
Not that this is about me but I wasn't thrilled that the 01 7.3L was lifted with all of those mods anyway
Good luck tomorrow and update us when you get home...perhaps with pics of your new truck if it works out
BManning
baking in Phoenix
2008 Ford Super Duty F250 XLT, 4x4, crew cab, 6.75' bed
5.4L V8 300hp/365ft-lb, 5sp Torqshift, 4.30 AAM gears
9400lb GVW 11200lb tow
2007 Volvo XC90 AWD V8
4.4L 311hp/325ft-lb, 6sp Aisin, loaded
6100lb GVW 5000lb tow
GrandAZ
Indiana / Arizona
Posted: 06/02/12 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Turtle n Peeps wrote:
Why the thumbs down? What did he see?
Let's see how good my memory is:
Hole in the radiator, Leaking water pump, rear main seal was shot and dripping oil making its way to the ground, bad carriers bearing(s), blown rear shocks, bad rear brakes, mentioned something was funny in the steering (had allloot of slop), seal on rear diff?, a few other seals (I forget which ones now), alignment issues, and tires bald as hell and almost slicks lol..... I feel like I am missing a few things but thats all I can remember.
Even with him doing the work as a friend and discounted from his normal rate said it had 2500-3K to bring it back.
2006 D/A 2500HD: SRW, CC, SB, 4x4
GrandAZ
Indiana / Arizona
Posted: 06/02/12 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Just went and looked at a D-Max.
'02 with 78K miles. Nice looking truck!: Lift, rims/tires, airbags, on board compressor, exhaust, 2 new batteries, new pitman arm, idler arm, idler arm bracket, Fabtech HD tie rods, new serpentine belt, a few other small things.
We didn't see much wrong on this one, tires were real bad and mechanic also told me that brakes were coming up soon, he said this one looked real good though.
How nervous should I be about the injector issues the '02 year had?? That is the only thing holding me back a little. I called the dealer here and they ran the VIN and could not see that it had ever had an work done on it. Still all original everything as far as injectors and all that stuff goes.....unless they were done somewhere else, truck was back and forth between AZ and UT.
Any suggestions?
45Ricochet
North Idaho
Posted: 06/02/12 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Where did the 2006 LBZ go Like 90% here suggested, you should look there.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Turtle n Peeps
California
Posted: 06/02/12 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
Some will dissagree but my opinion about the early D-max injector issue is not if but when.
Out of the handful of early D-max's my friends have owned ALL have had the injectors replaced. Some early, some late, some real late but all have had the first gen injectors replaced.
A friend just had them done with a few other nickle and dime stuff and the bill was a little over 5 grand.
I also wonder why brakes at 70k? I bet mine will have good brakes at 150K and that is not a fluke. Go ask around and you will find out this holds true.
For me no injectors no deal unless you can get 5 grand off of the price.
outside the fire"
NewsW
US
Posted: 06/02/12 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
GrandAZ wrote:
- 2000 Ford F350 7.3L with 123K miles.
I think for that kind of stuff to be on it, it is missing a "1" ahead of the claimed odometer reading.
or severe overload over its rather short life.
My truck had the carrier bearings replaced and also broken springs.
But it was known to be overloaded for much of its very hard life of over 1/4 million miles.
Paul Clancy
BC Canada
Posted: 06/02/12 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
I'd pass on an 02 dmax after owning one and having the injectors fail - as they all will with the lb7 engine. Also check for transfer case leak (pump rub). Not worth the bills you'll pay. 06 and up dmax are awesome.
jevanb
Montrose,michigan
Posted: 06/02/12 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 99sd7.3 and loved. It. But my current truck will pull night and day compaired. To that slug
2006 CC 4x Lbz, full of mods and more
2012 Wildcat 344QB
Pullrite Superglide
ksss
Eastern Idaho
Posted: 06/03/12 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have owned an 01,an 03 LB7's. The 03 got the best mileage of any Dmax I have owned. I put the first 80K on it and never had an injector issue (actually I have never yet had an injector issue on any Dmax). Until the LBZ's came out the 03 was the prefered year, upgraded interior (01-02's sucked I thought) and did not have any of the LLY issues and were easier to program. The LBZ is as others have said the way to go. Its probably the most sought after diesel on the market and the prices reflect it.
2006 GMC 3500 CC 4X4 D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2005 GMC 5500 CC 4X4 D/A
2012 Chevy 2500HD 4X4 6.0 3.73
GrandAZ
Indiana / Arizona
Posted: 06/04/12 11:24am Link  |  Quote  |  Print  |  Notify Moderator
RE: 45Ricochet (Computer throws a server error everytime I try and quote)
The 06 was my first choice but just my luck it was sold before I could get there.
Page of 9
