RV.Net Open Roads Forum: Class B - Camping Van Conversions: Inverters
rvdogmom40
Western Washington State
Posted: 06/01/12 09:53am Link  |  Print  |  Notify Moderator
I started a topic on another site about using a crock pot while driving down the road. Got responses from people who do this and one said they use a regular crock pot (not 12 volt) and an inverter. My knowledge ends with the crock pot. I understand that an inverter changes DC to AC. Can one buy an inverter and plug it in somewhere in the B (PW Excel)and have it do this "changing" to AC? Need info that isn't too technical :-)
Thanks in advance and if my CPC (crock pot cooking) works, you all are invited for dinner.
rvdogmom
enblethen
Moses Lake, WA
Posted: 06/01/12 10:03am Link  |  Print  |  Notify Moderator
It would take a healthy sized inverter to run a crock pot. Look at the specs for the crock pot to determine the wattage. You will need enough batteries to support the crock pot, and inverter for the time you want to use it. Batteries could run down enough to shut down your rig if alternator can't keep up.
Better choice maybe is to just run your genset if equipped withone.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
Grub
Pierre
Posted: 06/01/12 10:09am Link  |  Print  |  Notify Moderator
Energy efficiency wise it doesn't make any sense to run an inverter to run a crock pot and here is why.
The DC power in your car goes to the inverter to get changed to AC then to the crock pot which uses DC (yes it uses DC).
So why not save the $$ on an inverter and just use a portable 12volt DC crock pot?
Any day enjoying the great outdoors beats any day enjoying your 8x8 office cube!
smkettner
Posted: 06/01/12 10:10am Link  |  Print  |  Notify Moderator
Post the power requirements of the actual crockpot you intend to use.
Inverter will need to be hardwired to the battery as it will pull 20 to 50+ amps.
675 watts solar
2oldman
Wilson Creek WA
Posted: 06/01/12 10:11am Link  |  Print  |  Notify Moderator
When talking about inverters, it can get technical real fast. Maybe stick with a 12v one.
roadrunner16
Tucson
Posted: 06/01/12 11:48am Link  |  Print  |  Notify Moderator
I have a RT that has an inverter as standard equip. Its done the job well for years so Im saveing money by not buying a 12v model. There are inverters you can buy at any auto store if thats your wants.
Tom_M
New Hope, MN
Posted: 06/01/12 12:15pm Link  |  Print  |  Notify Moderator
A basic no frills slow cooker usually draws less than 250 watts on high. There would be no problem using an inverter while you are driving.
Tom
2005 Born Free 24RB
Horizon170
Jefferson, GA
Posted: 06/01/12 12:26pm Link  |  Print  |  Notify Moderator
I hard wired a 1200 watt inverter close to my batteries. I should have bought a 2000 watt. In my van I replaced the duplex recepticles with Quads. One side White for shore/generator power and the other side Yellow for the inverter. I ran all the wires myself and adhered to the electrical codes. All the yellows go to a 20 amp male plug that is plugged into the 1200 watt inverter. Now I can use whatever power is needed depending on requirements. I advise mounting the inverter near the batteries and use the proper gauge wire. The inverter will run everything except the A/C.
Marvin
Davydd
Minnesota
Posted: 06/01/12 01:02pm Link  |  Print  |  Notify Moderator
It is not a big deal. We could have done it in our 2005 Pleasure-way Plateau and did do it in our 2011 Great West Van Legend. We got the idea from a couple of people who have done it in a Leisure Travel Van Free Spirit. They all had one thing in common and that was an inverter already existing for the TV set. Our Pleasure-way had a 400w inverter and our Great West Van is a 750w inverter. The crockpot we used was a 1-1/2 quart crockpot of 120w, so the inverters were plenty big enough. Just plug in and go. While driving the alternator keeps up with the drain on the battery. This week on our way to Michigan's Upper Peninsula we had this beef pot roast going. Just put it in the sink for safety. We also used a tin can and another pot as wedges to keep it from shifting around.
Davydd
2011 Great West Van Legend Sprinter B Camper Van
Visited states in an RV
georgelesley
Minnesota
Posted: 06/01/12 01:16pm Link  |  Print  |  Notify Moderator
Just realize there is no "free" lunch. Making the engine alternator work harder and wear out sooner and will cost some gas mileage, as will running the rv generator.
George & Lesley
2013 Winnebago ERA 70A
