RV.Net Open Roads Forum: Fifth-Wheels: question on F-150 pulling 5th wheel
 > question on F-150 pulling 5th wheel
agesilaus
North Florida
Posted: 06/01/12 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Math doesn't work for me:
Pin weight around 1300-1500#
Hitch Weight 200#
Passengers and stuff in truck-- at least 400#
Overload on payload plus will the brakes stop that trailer in a panic stop on a steep grade?
Fords went to a 5.5 foot bed? My 2008 short bed F150 was 6.5 ft
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
rasteck
Northern California/East Bay
As said, the pin weight will put you over before you even add the hitch.
Of course that's just more free advice.
2000 Ram 2500 SLT/Laramie 24V CTD 2WD QCSB PacBrake, Smarty
2011 Colorado 320BS-FW 36'
EZ Flex + wet bolt
Curt E5 with R5 slider, Prodigy P3
Air Lift 5000's, Load Controller II
smkettner
Posted: 06/01/12 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Get an F150 with 8200 GVWR and still you will be at max so adjust your expectations accordingly.
look here for 8200 gvwr configurations:
http://www.ford.com/trucks/f150/specifications/payload/
675 watts solar
Dave&Monica
Ontario
Posted: 06/01/12 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
The truck will have enough power but the loaded pin weight will probably will at least 1600lbs and that weight will put the truck over it's GVWR and probably it's RAWR.
You really need the F150 with the max payload option (8200lb GVWR) to consider towing a 5th wheel.
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
fla-gypsy
North Florida
mguay wrote:
1. Pin weight will probably exceed the payload capacity....but I'm sure the weight police will chime in!
2.Irrevelant...I think.
3. Stephen King written all over it.
X2 with correction to #1. Pin weight WILL exceed payload capacity.
seattlefirervr
Snohomish, WA
Posted: 06/01/12 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
This setup can't be spun in any way to make sense, this is too much trailer for any 1/2 ton...period.
2006 31' Wildcat QBH,Yamaha 3000EFi Generator
2000 Ford F250 Lariat PSD CC,SB,4WD,AT. aFe Megacannon Airfilter,4" Diamond I exhaust,Custom"Evergreen Diesel"chip,Autometer pillar gauges,BD Torque Converter,ATS Turbo Housing,Wicked Wheel,BD Exhaust Brake,
Lady Fitzgerald
Tempe, AZ, USA, Earth
Posted: 06/01/12 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
...Fords went to a 5.5 foot bed? My 2008 short bed F150 was 6.5 ft
Most Screws since at least 2004 have 5.5' beds, including my 2008.
Jeannie
Lady Fitzgerald
Posted: 06/01/12 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Both the pin weight (including that heavy hitch) and the bed length (too short for turning) will kill you. You would be better off getting a TT for that truck. Keep in mind that you can't have both full towing capacity and full cargo capacity (load, tongue weight, etc.) at the same time.
therink
Rochester
Posted: 06/01/12 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
3/4 ton or less trailer and definitely not a fiver with 5.5 bed.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
scraig400
storage
Posted: 06/01/12 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Good stuff--thanks to all for comments.
