RV.Net Open Roads Forum: Class C Motorhomes: Magik's RV
 > Magik's RV
Page of 7
magik235
Central Wisconsin
Posted: 06/20/12 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
I used the 3M Eraser Wheel to remove 3 of my vinyl stripes on the driver's side. I cleaned up the paint where the previous owner touched up all the decals. It is harder to remove the paint than the decals.
1985 Sport Coach http://www.rv.net/forum/index.cfm/fuseac........d/tid/26101292/srt/pa/pging/1/page/1.cfm
magik235
Central Wisconsin
Posted: 06/21/12 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
With all the rain lately, my roof leak was much worse. I thought it was the side trim but I was mistaken. It was an annoying mistake because the sealing compound is a tacky mess. It took me hours to clean it up and now I have to drive to town and get the replacement.
magik235
Central Wisconsin
Posted: 06/22/12 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
I drove into town and bought the putty strip for the trim piece then reinstalled it. It was a total waste of time removing the strip but I learned how the top is assembled to the sides. I also replaced all the screws with stainless steel screws.
magik235
Central Wisconsin
Posted: 06/24/12 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
I removed more vinyl stripes. I am getting close to having them all removed. I will be glad when this is finished.
EMD360
Tempe, AZ
Posted: 06/24/12 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
3 M eraser? Is that a dry eraser or just fine scrubbie? I think I want to remove some of our peeling stripes. They are looking pretty ragged. My brother said to just use a hair dryer and a plastic scraper--he said he often just uses his fingernails and they come right off. Seems like I could skip the hair dryer in the AZ sun. Nice job on the list of work to your RV. Inspiring!
We're hooked!
2003 Itasca Spirit 22e
magik235
Central Wisconsin
Posted: 06/25/12 11:51am Link  |  Quote  |  Print  |  Notify Moderator
The 3M Eraser Wheel is a disk made of a rubber like compound that clamps into an electric drill. A video of it in action is linked below.
http://www.youtube.com/watch?v=HHKN5_UfDik
magik235
Central Wisconsin
Posted: 06/25/12 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
My end caps are cracked. The previous owner caulked them with silicon but it cracked. I think this is the source of my leak. I removed the silicon and cleaned the end caps. Then I masked the area and applied multiple layers of Marine Goop. After it set, I cut along the tape and removed it.
I thought I had a mouse nest in my blower so I removed it. It was easy access but the bolts were covered with a sealer so the socket would not fit. I was pleasantly surprised to see it was only a receipt instead of a mouse nest in the blower.
magik235
Central Wisconsin
Posted: 06/26/12 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
I worked on the driver's side top rear corner today. I removed all the old caulk then sealed everything with Marine Goop.
magik235
Central Wisconsin
Posted: 06/27/12 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
I worked on the passenger's side top rear corner today. I removed all the old caulk then sealed everything with Marine Goop.
magik235
Central Wisconsin
Posted: 06/28/12 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
I finished removing the copper orange vinyl stripes. I still have a section on the bottom of each side where they are painted. The bottom is aluminum so it will need to be painted after I remove them. I am trying to decide on a color to replace the brown.
Page of 7
 > Magik's RV
