I'm in a seasonal where we can't use AC since it's only a 15 amp service. Any draw backs or potential issues to consider before I pull that cool wire from the screw terminal in the thermostat? My thermostat is low and I'm afraid my kids will flick it to cool, I do plan on changing it to a digital thermostat at some point also.
Is there some value in keeping it powered up so that you can run the fan? If you have a wall themostat, just set the temperature up to its highest level and/or set it to a fan-only state.
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
Have you checked the voltage (under load) to see if it still might be adequate to run the air conditioner? Just use the microwave with a cup of water in it as a load and monitor what happens.
