tadpole2
Alba, Tx
When we turn on our hot water it make a high pitch noise. Thought it might have to do with pressure in last campground, but we have now moved and it is still doing it. Any suggestions.
tadpole2
trickyvic3
Raymond NH.
tadpole2 wrote: When we turn on our hot water it make a high pitch noise. Thought it might have to do with pressure in last campground, but we have now moved and it is still doing it. Any suggestions.
Is the noise coming from the tap? or the hot water heater itself.
tadpole2
Alba, Tx
trickyvic3 wrote: tadpole2 wrote: When we turn on our hot water it make a high pitch noise. Thought it might have to do with pressure in last campground, but we have now moved and it is still doing it. Any suggestions.
It is coming from the hot water heater.
Dog Folks
Naples, Fl. USA
If the noise is only when drawing hot water from the tank, it could be a Backflow preventer is broken on the tank. The parts inside it are rattling and will make a heck of a noise. We have had it happen twice. High pitched squeals etc.
Camping Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two "fur babies". A Basset Hound and a Chihuahua mix. Both are rescue dogs.
Fulltimers since June 2006
rv2go
Fulltime (Knoxville, TN).... or someplace else
Dog Folks wrote: If the noise is only when drawing hot water from the tank, it could be a Backflow preventer is broken on the tank. The parts inside it are rattling and will make a heck of a noise. We have had it happen twice. High pitched squeals etc.
x2 The backflow preventer can really make weird noises.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
jnharley
Anywhere, U.S.A.
I think it is operating normally. When our water heater is operating on electric, we can hear it and the noise could be considered a high hum. I think we can hear ours because of its location. It is in the basement but behind a wooden vent panel under the pantry in the kitchen area. We only hear the noise when water is heating.
2012 Dodge Dually
2012 Nu WA Discover America 355CK
tadpole2
Alba, Tx
Thanks for the help we will check out black flow preventer if we can figure out where it is. Thanks again
stickdog
29.820224, 81.94542
jnharley wrote: I think it is operating normally. When our water heater is operating on electric, we can hear it and the noise could be considered a high hum. I think we can hear ours because of its location. It is in the basement but behind a wooden vent panel under the pantry in the kitchen area. We only hear the noise when water is heating.
The same in our NUWA DA.
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Snow_King
Gold Canyon, AZ
Have you flushed the water heater with a wand? If you are in a hard water area, the it gets build up on the heating element. Might have to remove the element and clean it by hand. If while flushing it with a wand you get a lot of white stuff out, then I would pull the element. Be sure to turn off the AC before draining the tank. I have to flush mine twice a winter in Arizona.
Somewhere in a Fifth Wheel - Where it does not Snow
