RV.Net Open Roads Forum: Dinghy Towing: Ignition setting for manual shift toad
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Trailers & Tow Dollies
 > Ignition setting for manual shift toad
smsinville
Ohio
Posted: 06/03/12 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 32 ft Coachman class C and will pull a Nissan Frontier manual shift truck. It seems that the steering is NOT locked even when I turn the key to the first position. Can I tow it with the key in this position, or is there a reason for me to turn it one more notch so that it's in "accessory" position, making sure radio, fan, etc., are turned off.
Dr Quick
M'boro, Tn
Posted: 06/03/12 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
As long as the steering wheel is free to turn, that is all the further that you have to turn the key.
Dr Quick
tenbear
Northern Vermont, USA
Posted: 06/03/12 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Blue Ox brake box that plugs into the cigarette lighter. It does not get power until it is in the accessory position (2). If you require power you may have to set it in the accessory position.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
garym114
Bluff Dale, Texas
Posted: 06/04/12 07:58am Link  |  Quote  |  Print  |  Notify Moderator
The steering should not be locked.
Refer to the owners manual for towing instructions.
