RV.Net Open Roads Forum: Class A Motorhomes: Changing fog lights
 > Changing fog lights
Dune Chasers
Gilbert, AZ
Posted: 06/04/12 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 Fleetwood Expedition DP. My fog lights are not working and decided to check it out. The wiring looks good, so I began to remove one of the lights. I removed the 3/4" not on the back and pulled the light housing out to examine. I can hear something rattling around inside, so I'm pretty sure it's a bad bulb.
Now for my question. How do I get to the bulb? There it a solid housing around the glass and I can't figure out how to get to the bulb. I didn't try too hard since I don't want to break anything.
Any help would be appreciated. A part number for the bulb would also be helpful.
Thanks
othertonka
Stockton, CA
Posted: 06/04/12 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
I beleive it is a one piece sealed beam bulb, in other words you replacec the whole glass piece, there is no seperate bulb per se. Measure the diameter and google sealed beam 4 inch or what ever it measures. Or look for a part number on the inside of the sealed beam.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
rolnhome
Casa Grande, Az
Posted: 06/04/12 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure the engine is running and you are in gear. If I remember correctly the fog lights need to be in gear running with headlights on dim.
We're in Arizona
Dune Chasers
Gilbert, AZ
Posted: 06/04/12 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
I can't say I've ever tested them in gear, I'll check that out, thanks!
* This post was edited 06/04/12 09:54pm by Dune Chasers *
rolnhome
Casa Grande, Az
Posted: 06/04/12 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for not asking how I know.
Also make sure parking brake is off. As I think more about it I am pretty sure the parking brake being off is the key not being in gear. Might as well check it both ways.
