RV.Net Open Roads Forum: Adding a outside ladder
Blazing Zippers
North Idaho
Posted: 06/04/12 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone purchased a ladder to place on the rear of their trailer? Our trailer doesn't have a ladder and we would like one in case we need to get up on the roof. Any ideas, problems, thoughts?
Dave&Monica
Ontario
Posted: 06/04/12 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
If you camper is fiberglass exterior, the manufacturer has block/backing plates where exterior components mount ie ladders, awning, etc. If your camper didn't have an optional ladder you probably don't have anything in the wall to attach the ladder to. If the ladder was optional, you could get the factory ladder and instructions from them on mounting location.
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
robsouth
Near Atlanta, GA
Posted: 06/04/12 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
I'm no expert, but I have heard that trailers with ladders were reinforced during construction to accommodate a ladder and those with out ladders were not. Adding a ladder to a trailer would be a tricky move as you will likely not have the reinforcements behind the outer skin to attach it to. Good luck with your quest.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
dqdick
Council Grove, KS
Posted: 06/04/12 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
We have a ladder, but it's too small and light weight for me to feel comfortable on it so I just use it to hang my real ladder on.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
Blazing Zippers
North Idaho
Posted: 06/04/12 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
I was afraid of the construction issues. The outer shell is flat fiberglass and I'll bet there isn't much under it except for the aluminum frame work.
Thanks
tvman44
Southwest Louisiana
Posted: 06/05/12 03:05am Link  |  Quote  |  Print  |  Notify Moderator
X2
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
RockDodger
Northeast Illinois
Posted: 06/05/12 06:48am Link  |  Quote  |  Print  |  Notify Moderator
The general rule here is: If it didn't come from the factory with a ladder, your roof is not made for walking on. Before instaling a ladder I would check the schematic on your roof braces to make sure can walk up there. Don't want to end up inside prematurely.
Terry & Marsha
2007 Toyota FJ Cruiser, V-6, 4WD
1987 Sunline Satellite, 20', Reese anti-sway
Northeast Illinois
