RV.Net Open Roads Forum: Class A Motorhomes: Steer safe
 > Steer safe
jmanatee
Alstead, NH
Posted: 06/05/12 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have had Steer safe on 2 coaches 30,000+ miles neither had a bit of problems. I think like everyone else, improper install
Jon
RV Web Site | 50 Night Cross Country Trip
Our Solar Install | Roof Replacement Project
Twenty years from now you'll be more disappointed by the things you
didn't do than by things you did. Explore, Dream, Discover. Mark Twain
2008 Monaco Cayman XL 38PBD
fcooper
Richmond Hill, Georgia
Posted: 06/05/12 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
I installed my steer safe, and I can't see how the spring would fly off unless maybe the spring itself was defective (weak spot in the spring), or the spring was not put on correctly.
See if the manufacturer will give you a new spring.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
joe0508
charlotte
Posted: 06/08/12 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry it took so long to reply but i havent had internet for a while.I noticed that the eyes that the springs attach to none of the are tightened all the way down.steer safe says these eyes need to be tightened all the way down to the bar.I think this will be my problem.any thoughts on this being the reason for the spring coming off.Basicly not enough tension on the spring.
joe money
wagonmaster2
northcentral oklahoma
Posted: 06/08/12 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
I installed one myself on a '93 Chev chassis (42,000 miles) and one on a '97 chev chassis (53,000 miles) and never had a spring pop off. When installed correctly those springs are fiddle string tight and no way could you remove one without loosing the adjusting nut on the eyelets even if you tried. Someone undoubtedly slipped the springs on but forgot to tighten them up. Probably went on coffee break and forgot what he was doing.
Good suggestion above to contact the installer and get a new spring plus correct installation instructions. Also, if you weren't able to find the popped off spring could it be hanging up underneath the front end someplace?
Wagonmaster2
joe0508
charlotte
Posted: 06/08/12 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
yea i thought the same thing but no luck finding it underneath.I ordered 3 springs from steer safe tuesday and they havent arrived yet.If their not here by monday im giving them a call.I thought it would be a good idea to have some extra ones just in case it happens again.
ryanallie1
Magalia, Calif
Posted: 06/09/12 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
I agree that if the install was done correctely, I don't see how in the world if could ever come off by itself. Unless you had a Defective Spring to start with.
But even that one is hard to believe. I could see maybe one end of a Spring Breaking, but not both ends at the very same time.
But as life has some weird things happen, who knows for sure. I still believe that who ever installed your "Steer-Safe didn't do a very good job.
Adding a "Steer-Safe" to our Motorhome was one of the best Mods we have done to our Motorhome. We Love our "Steer-Safe". What a big differance it made in our Motorhome going down the roads. So good, I can easily steer now with just one hand.
Maybe you can use the extra springs for another project some day.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
roam1
Gulf Breeze FL
Posted: 06/09/12 08:00am Link  |  Quote  |  Print  |  Notify Moderator
When one spring is in tension, the other is compressed from the neutral position, I think if not adjusted properly, it could/would fall off. I think, not positive, probably installed incorrectly
 > Steer safe
