driver75
tomah
I got a 32inch flat screen tv and it fits great in the opening of my fifth wheel now how do I secure it to travel?
sharker6
fulltime KY, NC, FL, MA, TN
Take it down and lay it on the bed, screen down.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
Dennis M M
Geneva, IL; Tucson, AZ
After much futile searching I finally built my own. A triangular piece of 2x12, a square block drilled to match the TV mounting points, secured to the original slide out TV tray. Has worked well for quite a few years.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
ryanallie1
Magalia, Calif
Hi All.
We replaced both of our old CRT TVs with nice thin LED TV's. I just used Battery Strap Kits on both TV's.
Both of our LED TV's are on "Articulating Arms". So we can adjust the view to any angle, or Degree we want them to be at. Thats the Beauty of using "Articulating Arms".
The Battery Strap Kit comes with two Brackets also. Mount the Brackets, and just thread the Straps though them. They keep the TV's perfectly tight against what ever is behind your TV's.
I think I paid like $1 each for the two Battery Strap Kits with Brackets at ACE Hardware, on the table with Discounted items that sell very cheaply.
They work perfectly and hold the TV's from any movement what so ever. Cheap, easy to take on and off.
Most LED TV's if you look at the picture form much of an angle, you get to see a distorted picture or very fuzzy looking. Using Articulating Arms, I can adjust the Tilt and Angle to suit watching the TV's any where we chose to sit in our Motorhome. No more kinks in the neck or bad views.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
donn0128
Pronounced Ore-gun
Two screws through the base and a strap around it during travel is probably all you need
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Alpenliter
Fulltimer: Wherever we are!
Since I built mine into the original tv cabinet, like Ryanallie I used an articulating arm. When we travel I use a cut down spring loaded shower rod that I covered with a piece of foam pipe insulation. Pop it into the cabinet corner to corner and the tv stays put. Takes 2 seconds to install or remove.
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
DeadeyeLefty
Sunshine Coast, BC
Quote: I just used Battery Strap Kits on both TV's.
That's how we've been doing it on boats for years. Simple and effective.
Project Glacier trailer build.
Artum Snowbird
Campbell River, B.C., Canada
I mounted a 27 inch unit on a very secure swing arm. The TV fits into the slot for the larger removed unit, and I made two "gate" arms that drop to horizontal to hold the TV in place, and swing up to vertical to allow me to pull the TV out and use it on it's swing arm. The weight of the arm holds it in the horizontal position by gravity on the longer leg.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
hitchup
Fulltiming and on the Road.
Our LED sits just outside the opening of where the original LCD sat. So we use bungee cords hooked up to new arm to prevent bounce.
2009 DRV Mobile Suite 38TKSB3 (38RSSB3)....our custom home w/2011 upgrades
2010 Ford F450 KR CC 4x4......his office
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
Peg Leg
Anderson, IN
I have my 32" mounted with 2 bolts through the base and shelf, a short angle bolted to the back mounting holes and a metal strap from there to the back shelf.
I used this method in my 31' TT for about 4 yrs and now have it in my 5er. It works for me.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker II LS 29.5 FKTS
Yamaha EF3000iSE
retired gadgetman
