RV.Net Open Roads Forum: Truck Campers: test
d3500ram
colorado
Posted: 06/05/12 09:48am Link  |  Print  |  Notify Moderator
test post... cannot post in ATC, just seeing if I can here..
Mods... please delete if this shows up.
Hmmm...? not sure why I can post here, but not in the ATC forum?
* This post was edited 06/05/12 10:07am by d3500ram *
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
2008 NorthStar Arrow short bed.
pulsar
Lewisville, NC
Posted: 06/05/12 10:29am Link  |  Print  |  Notify Moderator
The RV.Net portal has issues with certain characters. For example, it can't process percent symbols nor "smart" quotes, both single and double.
If you are having trouble posting through the RV.Net portal to the Open Roads Forum, you should try one of the others; for example, Woodall's
In addition, if the file name for the picture contains a space, many host sites will change that to a %20. The RV.Net portal will not be able to process the %.
Note: I am posting through the RV.Net portal, but used a trick to post the percent symbol, above. Anyone quoting this post, while using the RV.Net portal, will have trouble posting. Using the other portals, there won't be a problem.
Tom
wnjj
Cornelius, Oregon
Posted: 06/05/12 10:55am Link  |  Print  |  Notify Moderator
You callin' d3500ram a "certain character?".
JoeChiOhki
Sauvie Island, OR
Posted: 06/05/12 11:17am Link  |  Print  |  Notify Moderator
Actually, I believe unless you flag the topic as a picture post in the ATC Picture sub-section, it won't appear.
CB Channel 17 Redneck Express
d3500ram
colorado
Posted: 06/05/12 11:43am Link  |  Print  |  Notify Moderator
LOL... I resemble that resemble that remark
Actually, I was trying to post a normal reply in the ATC... no pictures or anything... and using Woodalls.
d3500ram
colorado
Posted: 06/05/12 03:05pm Link  |  Print  |  Notify Moderator
So I tried again to post in a running thread (just a normal reply) and I can neither preview it nor make the post via either post reply or quick reply I just get the continiuous web browser spinning thingy.
...but here it seems OK by virtur of this reply!
Have I been banned by the ATC Mods? (I have not poste anything offensive in a LONG time... heck I have not been too active here in a long time.)
