Allegheny N F Camper
Pennsylvania
I wil be up graging from a TT to a 5er next Monday. I will not disclose the size make or model to avoid turning this into a weight police tread. But I just wanted to see what kind of advice the old pros out there would give on hooking up and hauling a 5er for the first time and what to watch out for. I do have a class A cdl so heavy hauling is not new to me and I have a DOT map and have planned my route to avoid steep hills.
Antique Deere
LaGrange, IN USA
Be sure to swing wide when you turn corners. The pivot point on a fifth wheel is in the center of your truck bed, versus on/near the bumper.
Bob T
big bird 2
La Crescenta, CA
Take it slow and easy. This is a big box that is not very forgiving. You and your wife need to learn together and become a trusted team. Outsider help will fail you most of the time.
Have fun and I hope it is not too long. Bigger is not better.
Big Bird 2
ford truck guy
Pennsylvania
Good luck with your new 5er... Just remember the basics and since you already have your class A , you should be ok to go at at !! ( I hope ) ... Remember to do your pre trip , DO NOT high hitch , make sure you allow the pinbox to ride up your hitch...Remember the pivot point is different than that of your TT , it will back up differently but you will get used to that..
Joe and Lori
2009 Ford F350 SD 6.4
08 Montego Bay
Hers are my pictures
Captivao7
North Jersey
I went from a 32'TT to a 37' 5er and was not that bad towing.
Have fun.
2008 Silverado 2500
2012 CC Silverback
SuperDutyMan
Western PA.
Been there, done that,ask lots of questions at dealer,and just take your time and double check everything,watch your height,you'll be fine,congrats on the new 5ver!
2011 Palomino Sabre 31RETS,5th Wheel,Triple Slide,4000W Onan Genset
2006 Super Duty,XLT, V10, 6 Speed, 4.10, Tow Command, Tow Pkg. 4X4,Dual Exhaust,K&N,Reese 15K,Air Bags
amxpress
Clayton, NC
Take a look at this video on You Tube:
http://www.youtube.com/watch?v=jLxkhV03iCo
Enjoy your new fiver!!
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L denied parole! Yeah!
joebedford
Jasper, Ontario
That new 5er is definitely too light for your truck.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
Billieg2
Gone from this forum
1- Make sure you have at least 5 1/2 inches from your bed top rail to the 5th wheel and the 5th wheel is level.
2- Make sure your truck and hitch is rated for the 5iver weight and is greased.
3- Make sure your brake unit is set right to stop the 5th wheel
4- Check to see if the 5th wheel will hit your cab on a hard turn
5- Make sure you know when the 5th wheel has passed someone.
Good luck!
In my life I've spent my money on women, booze, Harleys, guitars and traveling, the rest I just wasted...
2007 Ford F-350 diesel/dually & Sunnybrook Titan KSRV 39-1 Toy hauler 5th wheel hauling my custom Harley
FunnyCamper
Southeastern
we bought a 5er 2 weeks ago never owning one. we had no troubles. just listen to the service guys when they walk you thru the hitch set up and unload etc.
it pulls fine. that 'chucking' is weird. but people on the board explained it to me so I felt more at ease. first big 'chuck' freaked me out
other than knowing the steps to hitch and unhitch, there isn't any other secrets that we have learned. it is fast, easy vs. the TT we owned and no problems so far.
ENJOY that new 5er!!!
