David0725
I might me a stupid question! But how do you get the level On the camper level if the campers not level?...lol by guess it just hold it level then just stick it on. if the TT not level it sould show when you let go. right?
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
usmc616
Orange County, New York
My last 3 TT's were aluminum sided so I lined the level up with the lower edge of one of the siding panels.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
tessa25
Colorado
Borrow a real level from a neighbor. Level the camper. Put on the 'stick on' levels. Return level to neighbor (or he'll never lend you his stuff again).
Palomino Gazelle G150
David0725
tessa25 wrote: Borrow a real level from a neighbor. Level the camper. Put on the 'stick on' levels. Return level to neighbor (or he'll never lend you his stuff again).
I was thinking I could do that off the frame right? And where is the best place to put them?
ScottG
Bothell Wa.
Level the fridge by using the neighbors level because thats the most important part to be leveled. After that you can install the stick on levels and the rest of the RV will be close enough.
Scott, Grace and Wesly
H0NDA eu2000i
eric james
Sioux Falls, SD
Use your carpenter's level until the one time you get it perfectly level then stick on the bubble levels.
I leveled at a couple areas of the floor.
I still lay in bed and night and can tell if I'm off level a bit and can fix it the next morning.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
PapPappy
Wilmington, NC
It will probably depend on what you want level? If you worry about your sleeping, then maybe you should lift the mattress, and put a level on the bed platform....adjust the RV so that it's level, and then put up your stick-on levels.
You can do the same thing with the galley table, the fridge, the floor, or the frame.....but more than likely, you'll get a different version of level at each place
It really depends on how picky you are
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
mtofell1
Oregon
eric james wrote: I still lay in bed and night and can tell if I'm off level a bit and can fix it the next morning.
When this happens to me I just pour another drink. I've found it's easier than going outside at night jacking up the trailer
pasusan
PA
PapPappy wrote: It will probably depend on what you want level? If you worry about your sleeping, then maybe you should lift the mattress, and put a level on the bed platform....adjust the RV so that it's level, and then put up your stick-on levels.
It really depends on how picky you are  You forgot the stove - lots of folks like their eggs to not run to the side of the pan.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
sharker6
fulltime KY, NC, FL, MA, TN
Level the trailer by placing a torpedo level under the window sills on the exterior. Front or back and one side, takes five minutes. I've never relied on the stick-on type.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
