RV.Net Open Roads Forum: General RVing Issues: TIRES (I know...)
 > TIRES (I know...)
dcmac214
SW OKLA
Posted: 06/06/12 11:24am Link  |  Quote  |  Print  |  Notify Moderator
More LT vs ST. I know, ad nauseum...comments invited anyway...
Went to seven (7) tire places (5 tire dealers, 2 RV). All tell me I need ST primarily because the sidewalls are thicker/stiffer. 4 of the 5 tire dealers showed me LT & ST side-by-side and it seems they may be right, the ST are much stiffer than the LT (including Michelin). In fact, the LT sidewalls were so flexible makes me wonder if they're really suitable for 1T & heavier pickups. The ST felt heavier, too.
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 06/06/12 11:46am Link  |  Quote  |  Print  |  Notify Moderator
They are correct. Want a good tire? look at Greenball Towmaster Radial Special Trailer Tire. I got four for $500 balanced and installed two years ago.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
bob213
Fresno, CA
Posted: 06/06/12 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Once you get past a Maxxis 15" tire, I believe it becomes more of a quality and availability issue with the LT tires. You can buy a "good" quality 16" LT tire almost anywhere. Stuck on the side of the road it will be much harder to find a 15" Maxxis (the only ST to buy) than the LT tire. JMHO
donn0128
Pronounced Ore-gun
Choose what you want. If you have/had read the threads over the past six months there would be no question in your mind. There are some on here who insist ST tires are the way to go. The same ones have blown out somewhere around 20-25 ST tires in recent years. On the other hand those of us with LT tires are still merrily tooling along on our LT tires with no hint of problems except the occasional nail etc. I just took off my OE LT tires from my 2005 fiver. Replaced them with ????? You guessed it LT tires.
* This post was edited 06/06/12 12:01pm by donn0128 *
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
BB_TX
McKinney, Texas
Posted: 06/06/12 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with donn0128. You often hear about OEM ST tire blow outs. But much lesser so about an LT tire blowout. And some manufacturers are putting LTs on their trailers.
Don't know that you can go really wrong with either. But it is LTs (Michelin) for me.
502_Jimmy
Richmond VA
Posted: 06/06/12 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
I put these on my TT and could not be happier... I went from a 28lbs ST tire to a 52lbs LT tire. Steel sidewalls, heavy duty everything... in a LT225/75R16 flavor...
Bridgestone Duravis R250
By far, the most heavy duty tire I have ever owned, on both a trailer and a truck... These are fantastic! I can now pull my TT without fear of constant blowout..
John
Snow_King
Gold Canyon, AZ
Posted: 06/06/12 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe they showed you Maxxis ST8008's or Goodyear G614's. Here are some tire weights.
1. Michelin XPS RIB LT235/85R16 LRE (rated to 3042lbs) Weight 55.41
2. Goodyear G614 LT235/85R16 LRG (rated to 3750lbs) Weight 57.5
3. Bridgestone Duravis R250 LT235/85R16 LRE(rated to 3042lbs) Weight 60
4. BFG Commercial TA LT235/85R16 LRE(rated to 3042lbs) Weight 44.44
5. Uniroyal Laredo HD/H LT235/85R16 LRE(rated to 3042lbs) Weight 44.44
6. GY Marathon ST235/80R16 LRE(rated to 3420lbs) Weight 35.4
7. Maxxis ST235/80R16 LRD 3000 lb rating at 65 lbs of air weights 38.58
8. Maxxis ST235/80R16 LRE 3420 lb rating at 80 lbs of air weights 43.43
9. Duro 2100 ST235/80R16 LRE 3520 rating at 85 lbs of air weights 35.5
10. TowMax ST235/80R16 LRE 3420 lb rating at 80 of air weighs 35
Somewhere in a Fifth Wheel - Where it does not Snow
Chuck&Gail
In the Colorado Mountains
Posted: 06/06/12 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
What SIZE tire do you have?
If 15", IMHO Maxxis is the way to go. If 16" there are LOTS of choices.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
wandering1
Posted: 06/06/12 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
They want to sell ST tires. LT tires are better for trailers because of the greater reserve capacity and are stronger. LT tires do blow out but not as often as ST tires.
Heavy-Duty-LT-Truck-Trailer-Tire
HR
FastEagle
Taylors, SC
Posted: 06/06/12 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
The following quote can be found in the RMA document (chapter 4, page #49) in the reference listed below.
“Tires specifically designed for travel trailer use in highway service have an "ST" (Special Trailer) molded on the tire sidewall (ST225/75R15 or ST235/80R16). ST tires have different load capacity characteristics. Therefore, ST tires should not be
replaced with any other type tire.”
RMA Ref.
FastEagle
Dickinson, ND
 > TIRES (I know...)
