RV.Net Open Roads Forum: Fifth-Wheels: screw lengths for outside wall penatration
 > screw lengths for outside wall penatration
83trekker
calgary,ab,canada
Posted: 06/07/12 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
I am going to screw my backup camera on the back of my 98 5th wheel Kit companion. What length would be the best to use, i dont know how thick my walls are. Also just a regular wood screw good?
downtheroad
Pacific Northwest
Posted: 06/07/12 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Not familiar with your exact model but I would look in behind a cabinet where plumbing lines come in or in an outside storage compartment. You should be able to find enough exposure to see how thick the walls are.
My guess (don't hold me to it) is that 1 1/2" in (one and a half) length would be safe.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 06/07/12 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
You could also remove an existing screw from something like an exterior light and see what length it is.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
83trekker
calgary,ab,canada
Posted: 06/07/12 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thats a good idea.
The back of camera is feather light so it doesnt need heavy screws at all. I am also putting a drip cap over it. Should i put that gooey stuff around the screws like everything else screwed into my 5th wheel?
ScottG
Bothell Wa.
Posted: 06/07/12 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
The immediate skin is only going to be 1/8 to 3/16" max thickness so you only need a very short screw. Also, I would opt for a stainless steel screw to prevent rust and help preclude leakage.
Scott, Grace and Wesly
H0NDA eu2000i
Mile High
Denver, CO
Posted: 06/07/12 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Your probably just going into a thin fiberglass gell coat, so they won't need to be long.
Most of the factory equipment installed as a wood backer or additional fiberglass - so the length of the other attachments may be misleading.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
83trekker
calgary,ab,canada
Posted: 06/07/12 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is actually aluminum siding.
jw of 4 corners
Rhode Island
Posted: 06/07/12 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Open the door and measure the jamb thickness, that is the wall thickness.
Have Fiver will travel with little or no notice at all.
Lov2hittheroad
Ca
Posted: 06/07/12 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Go with a Stainless #10 3/4 sheet metal screw threaded the full length, can be found at big box stores. Also pre drill a pilot hole smaller by a tad then the inside diameter of the screw looking at the side profile DO NOT include the flair out from the thread just the shaft down the center. Smaller is usually better....fill the hole with silicone for water proofing. This is of coarse for a fiberglass exterior. If the rig is metal, go with a polyurethane adhesive. Can be found at big box or hardware store, comes in toothpaste size tube or caulking gun size. Where gloves, stuff is sticky as pancake syrup. Glue and then duct tape just the bracket in place over night. Caution once it is glued its there for eternity. Good Luck
Blessings,
