RV.Net Open Roads Forum: Travel Trailers: Towing combination
 > Towing combination
racnaa
Winchester VA
Posted: 06/07/12 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
I am heading out this weekend, and just looking for some peace of mind. I will be pulling a 23 foot 1979 Nomad that weighs about 5500 lb loaded with a 2001 chevy extra cab silverado z71 5.3 v8 with 3.42 gear. Does this sound like an overloaded situation? I am using a weight distributing hitch and a single friction sway control. Thanks This will be the first trip for this combo.
* This post was edited 06/07/12 04:08pm by racnaa *
sharker6
fulltime KY, NC, FL, MA, TN
Posted: 06/07/12 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your well within the limits of the truck & the hitch setup is fine.
2009 30' Fleetwood Wilderness, 2008 F-250 Super Duty FX4 stump puller
racnaa
Winchester VA
Posted: 06/07/12 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
MitchF150
Washington, the State
Posted: 06/07/12 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
I think you'll be fine too.. Don't be surprised if you have to downshift into a lower gear more often than you are used to and that it will take longer to get going and coming to a stop.. But, that's what comes with towing a TT, so it'll be 'normal'.
It might take you several trips with the rig to get the feel for it and to learn what the truck likes and does not like. Where it's 'sweet spot' is and the like.. I've been towing my rig for 10 years now and while I pretty much know it now, it took me a year or 2 to really dial it all in..
Good luck and have fun!
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
1mtnman
Colorado
Posted: 06/07/12 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Depending on terrain you should tow in 3rd rather than try to tow in Drive. Your vehicle will be no powerhouse with the 342.1 rear ratio however if your towing is mostly level to small hills your TV should be adequate.
Peg Leg
Anderson, IN
Posted: 06/07/12 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Don't try climbing long hills with your foot to the floorboard. Let the truck downshift and stay in the right lane.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker II LS 29.5 FKTS
Yamaha EF3000iSE
retired gadgetman
racnaa
Winchester VA
Posted: 06/08/12 05:36am Link  |  Quote  |  Print  |  Notify Moderator
Yep I plan on using tow haul and third and goin about 60-65. I have already found that when pulling my car trailer and street stock dirt car that the 5.3/3.42 gear combo doesnt have the balls that my old 90 gmc with 5.7 and 3.42's had.Thanks again for the advice .
* This post was edited 06/08/12 06:25am by racnaa *
rgolding
Southern Illinois
Posted: 06/08/12 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Check those trailer tires, have fun.
LTCLarry
Maggie Valley, NC
Posted: 06/08/12 06:52am Link  |  Quote  |  Print  |  Notify Moderator
That should not be a problem rig. Enjoy your "peace of mind" as it happens I'm headed out at 11am for the weekend myself.
APT
SE Michigan
Posted: 06/08/12 07:55am Link  |  Quote  |  Print  |  Notify Moderator
Keep overdrive locked out. Expect plenty of time in second gear climbing. Keep the torque converter locked up as often as possible. Enjoy the trip!
2012 VW Passat TDI
