RV.Net Open Roads Forum: General RVing Issues: bad odor in camper
 > bad odor in camper
machunt
cincinnati ohio
Posted: 06/07/12 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
2011 321 frl outback and we are experiencing a very bad odor from under the kitchen sink. we replaced the vent that is under the sink. any ideas
fordsooperdooty
Posted: 06/07/12 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Ad some enzyme digester to your grey holding tank...
LostinAZ
At Home
Posted: 06/07/12 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
You may be smelling the vent to the roof for the galley tank. But since you say you smell it under the sink and you have no visible leaks I would suggest filling the galley tank through the sink drain filling it to where water is standing in the sink. Then start looking for leaks both inside the 5th wheel and underneath.
path1
seattle
Posted: 06/07/12 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure the smell is a tank smell? No chance of a mouse or rat or cat or whatever died back in there somewhere?
* This post was edited 03/11/13 01:37am by path1 *
(To cheap to buy new)
1990 37 ft 5th wheel that hasn't moved since 1996 (our best home)
1997 33 ft trailer (winter home in much warmer climate)
2005 25 ft M/H (our "stand up B" for traveling)
pkunk
Questa, NM
Posted: 06/07/12 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
"Might find something smelly nobody knew about."
Like a rotten potato....
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
rconkin
Jonesborough, TN
Posted: 06/07/12 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Funny that you would mention rotten potatoes. Two summers ago we had a terrible odor and thought it was from one of the holding tanks. We also had a problem with fruit flies most of that season. Tried every cure for fruit flies we could find on the internet but they kept coming back. Made sure we put stoppers in the drains on kitchen sink, but them flies kept coming back. The odor finally went away. At the end of the season while winterizing our 5er I opened that cabinet under the stove that we decided since the subwoofer to the surround sound was in there was basically useless and found the bag of potatoes, or I should say the liquid they had turned into, that I had put under there at the beginning of the season. I had to admit to DW that I was the cause of the odor and fruit flies.
Search every little nook and cranny.
04 Dodge 3500 CTD, DRW, 4X4, Quad Cab, Edge EZ, AirDog II, B&W Companion, Prodigy P3
13 Montana Mountaineer Edition 346LBQ
"For those that fought for it, Freedom has a flavor that the protected will never know!" Semper Fi
pjhootch
Iowa
Posted: 06/07/12 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing a dead mouse back behind the floor or wall.
P.J.
2006 Winnebago Outlook 31C
WandaLust2
TN
Posted: 06/07/12 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
The mystery stink. We had that with our 1st TT, an old 82 Sunline. We never found the source of the odor. It was a foul sour cheesy smell coming out from under the sink/stove area. We tried everything from scrubbing the floor under them with bleach water, then strong Pine Oil cleaner to spraying loads of Lysol and letting a fan blow into the opening... the smell remained. All we could think of was something, some food or milk product was spilled and somehow got into the flooring and bottom of the wall behind the sink/stove unit. We had that TT for a year and the smell never dissipated.
WandaLust. Retired. Middle TN
Heartland 2011 NorthTrail 28BRS
1993 Ford Dutchman Class-C
machunt
cincinnati ohio
Posted: 06/08/12 07:48am Link  |  Quote  |  Print  |  Notify Moderator
if it were a dead rodent it would stink all the time. we are gonna bleach the tank on sunday when we dump
