Obsolete
OnTheRoad
I'm wanting to buy a Mark 8000 water softener for my MH. It won't fit in the compartment, so I'll have to hook it up on the ground before the water goes into the utility compartment, like others I've seen. I don't see any way to lock it. Has anyone heard of those things being stolen? Has anyone found a way to secure them? Is this something to worry about?
National Tropi-Cal - 36'
with Banks PowerPak
2oldman
Wilson Creek WA
Don't worry about it.
tandkj
Full timer
I put a chain on mine just for dressing. No one has ever bothered with it.
Tis another fine day to serve in and for the glory of the Corps. Every day is a holiday and every meal a feast.
08 Camelot
07 Ranger Toad
One Golden Retriever at the Rainbow Bridge and a new one traveling with us.
pkunk
Questa, NM
If you're really in a seedy place and worried it'll walk, fill your tank with it and put it away. Problem solved.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
kennethwooster
Perryton Tx USA
Dealer took my water softner and mounted it in the storage compt. He put by pass kit on it such as would be on hot water heater. Course if you don't have room for it it is a different matter. Definitely works well.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
wagonmaster2
northcentral oklahoma
Gads, I've been worrying about my new Winegard Carryout Satellite Dome walking off but hadn't given any thought to the water softener doing the same thing. Always something to worry about isn't there?
Wagonmaster2
mlts22
Austin, Texas
I'd stick a security chain on it and call it done. A tweaker will realize it can't be cut off with bolt cutters and look for something else. A professional thief will not waste his/her time.
If it is a really nasty place, I'd do as above -- fill the FW tank and then stow it, or find yourself a better CG.
dqdick
Council Grove, KS
Haven't lost ours yet, or anything else for that matter.
Dick and Joyce
2010 Montana 3665RE
Dodge 2500HD Maxi Cab Laramie Edition
Diego, Norm, & Bitsy
sc3283
St Louis
I'd be looking at another CG if I had to worry about theft
04 D-Max Crew Dually
96 Monaco Dynasty 36'
navegator
San Diego CA.
Place it if you can inside a new clean sewer hose no one will even think of touching it.
Navegator
