RV.Net Open Roads Forum: Fifth-Wheels: Chocking on a steep hill
 > Chocking on a steep hill
robthebruce
California
Posted: 06/10/12 10:44am Link  |  Quote  |  Print  |  Notify Moderator
We upgraded our little Skyline 28 foot to a Landmark Rushmore 39 foot this week , however it needs to get parked on the street which is steep.
Any ideas to help with the wheel chocks?
I have the giant rubber one's now , but thinking of a wheel lock also.
Please chime in on this , I dont want a 12k 5th wheel running down the street one day.
bpounds
Whittier CA
Posted: 06/10/12 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Are you going to be unhitched on the street? That would scare me too on a steep graded street.
I think chock blocks are more effective than between the tire chocks. In fact, I have little use for any between the tire chock as far as a roll-away is concerned. So I would first make sure I had blocks behind all 4 tires. And if it was going to sit there for a while, I would make up some chock blocks where the tire rested on a plywood sheet under the tire attached to a block behind the tire. Those can't slip out or be kicked out.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
sch911
Rochester Hills, MI
Posted: 06/10/12 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Parking un-hitched on the street is illegal in many places. Check your local ordinances!
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
45Ricochet
North Idaho
Posted: 06/10/12 11:22am Link  |  Quote  |  Print  |  Notify Moderator
What kind of grade you talking about here? Big grade in earthquake country don't sound like a good mix.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
mnm#2
pittsburgh,pa/usa
Posted: 06/10/12 11:33am Link  |  Quote  |  Print  |  Notify Moderator
We like the large rubber chocks. The x type wheel locks will become lose when when the tire cools and the diameter decreases.
robthebruce
California
Posted: 06/10/12 11:34am Link  |  Quote  |  Print  |  Notify Moderator
, good idea on the wood, I have 4 giant chocks for the tires , and was since its short term i was gonna pull the breakaway cable also.
Might just leave the rig hooked up to it.
m&d kelly
Redlands, CA, USA
Posted: 06/10/12 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
A set of Rotochoks and almost any block will work great. I have used the rotochoks ever since we purchased our 5er and have chocked on some steep grades temporally. They are very solid. The chocks under the wheels are for backup safety.
Mike & Dava
2007 Sierra Classic 2500 HD Duramax/Allison 4X4 Crewcab, Super Springs
2005 Carriage Compass 30RLS, MOR/ryde suspension & Pinbox, Onan 3600LP
Huskey 16K EZ Roller, DigiTrac
robthebruce
California
Posted: 06/10/12 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
I was looking at those , they look real solid
Jim-Linda
Livingston, TX
Posted: 06/10/12 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
DO NOT pull the breakaway cable!! You will discharge battery fairly quickly and possibly burn out the brake magnets! That device is to be used only to stop trailer in case of truck/trailer disconnect while moving. Plus the braking effect will not occur as the wheel needs to be rotating for brake shoes to engage.
jim
Don & Linda
Western PA / Cape Cod
Posted: 06/10/12 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
jim
X2
