roam1
Gulf Breeze FL
I called CW and asked if they had Eternabond. They answered yes, come on down. I drive an hour in the rain and they point me to a Dicor tape that he said was Eternabond relabled. When I do a search on the CW website for Eternabond all that comes up is the Dicor tape. Is this a bait and switch? I did not want to apply any type of permanent tape without making sure it was the real mccoy. Anyone know if they are the same?
thanks!
rolnhome
Casa Grande, Az
From my research they are made by two different companies..
Your results may vary
We're in Arizona
Weathertodd221
FL
ABC roofing supply sells the Mulehide brand which I know for a fact is relabled Eternabond. There is an ABC supply in Pensacola.
Dicor stuff needs 24hrs to set?? Pass.
past-MIdirector
Michigan
Same stuff but made by different companies. Camping World stocked Eternabond until Dicor came out with there's. Used both, they apply, stick, and last the same. I've found no difference.
fordsooperdooty
EternaBond is a patented, propriatary Micro-Encapsulated adhesive tape that is not sold under any other brand name. DiSeal Tape is a "wannabe" substitute.
Camping World doesn't carry EternaBond...WalMart does.
Per Dicor, DiSeal is "water resistant".
The fact is that EternaBond can be used and installed in the rain, and even underwater in a a swimming pool.
roam1
Gulf Breeze FL
fordsooperdooty wrote: EternaBond is a patented, propriatary Micro-Encapsulated adhesive tape that is not sold under any other brand name. DiSeal Tape is a "wannabe" substitute.
Thanks
I've read so much good about the brand name Eternabond that I don't want a substitute, I'll try WalMart
Weathertodd221
FL
you are incorrect. I can send you the proof via PM if you'd like.
Weathertodd221
FL
roam1 wrote:
Thanks
http://www.mulehide.com/acrobat2/literature/10.00701.pdf
roam1
Gulf Breeze FL
Thanks but..............just got back from WalMart with enough to do my job!
SCVJeff
Santa Clarita, CA.
Weathertodd221 wrote: fordsooperdooty wrote: EternaBond is a patented, propriatary Micro-Encapsulated adhesive tape that is not sold under any other brand name. DiSeal Tape is a "wannabe" substitute.
you are incorrect. I can send you the proof via PM if you'd like. I'd like to see that too since there is a CW 10M from here. I looked at the link you posted and there is no mention that it is sold under license or re-branded.
Jeff - WA6EQU
