joe0508
charlotte
I have a 92 chevy p 30 chassis and thinking about getting a compressor and dual gauge to monitor my coilspring airbags.Anyone know what system i should go with that wont break the bank.I think i can get by with a standard compressor but not sure.I have been looking around on the web and the cheapest i have found was like 300 and that was firestone.I have firestone airbags so dont know about going with another brand name.Just thought i would ask in case someone knows of a better deal.
joe money
Gale Hawkins
Murray, KY
joe0508 wrote: I have a 92 chevy p 30 chassis and thinking about getting a compressor and dual gauge to monitor my coilspring airbags.Anyone know what system i should go with that wont break the bank.I think i can get by with a standard compressor but not sure.I have been looking around on the web and the cheapest i have found was like 300 and that was firestone.I have firestone airbags so dont know about going with another brand name.Just thought i would ask in case someone knows of a better deal.
What happened to the SS coils you were installing?
joe0508
charlotte
Just to much.It will break the bank.Gonna try to fix the bags and get a cheap montoring system so i can keep an eye on the pressure.
Gale Hawkins
Murray, KY
joe0508 wrote: Just to much.It will break the bank.Gonna try to fix the bags and get a cheap montoring system so i can keep an eye on the pressure.
Man you stay up late making up things to post?
bsinmich
Holland, MI
I can remember when his sign in was Joe Money. Maybe that is why he changed his name. No more money. He has a motorhome.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
weathershak
Not sure, I need to look out the window
JMO... I changed my air bags, put 70 psi in them and check them once a month. No lines, no gauges, just crawl under and check them. Without the air lines, I am forced to crawl under there to check them, which gives me the opportunity to check other things out, for oil leaks etc. I have talked to a few that had more problems with the air lines leaking, so I elected not to use them.
Full timing it since July 2012 My pics
joe0508
charlotte
Guess 300 will be the cheapest.Thanks for the input.
joe0508
charlotte
I have a right to change my mind right gale hawkins.
Hurricane Owner
Riverside
You can piece part a system at airbagit.com. Use the $109 air compressor, and the push button single gage, with dual needles. 1/4" airline, and fittings will get you what you need.
jetboater454
Camping or home
Or you can get the cheap air 12V compressor at walmart,take it out of the case,mount it anywhere and get a control valve for the air and a switch for the power.About $60.,plus cost of air lines.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
