RV.Net Open Roads Forum: Truck Campers: Lance 6 pin
 > Lance 6 pin
ridinpreacher
Round O, SC
Posted: 06/10/12 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a plug adaptor to go from Lance 6 pin/way male cord end to the 7 pin/way female on the truck. Or is there a site to get a wire diagram to splice a Lance compatible 6 way female to the truck's wiring harness?
Desert1667
MD
Posted: 06/10/12 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a Link to the lance wiring,
www.lancecamper.com/docs/trailer-owners-manual.pdf
Desert
Reddog1
El Dorado, CA
Posted: 06/11/12 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I preferred to change the 6-pin on my TC to the seven pin. I originally used an adapter, but constantly had to hunt for it when I loaded my TC.
You can buy an adapter from most Auto parts stores, Walmart or RV parts stores. If your TC is wired correctly, should plug right in. "Plug-n-Play"
Wayne
mkirsch
Rochester, NY
Posted: 06/11/12 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Be glad you can get the wiring diagram. I had to figure out the wiring the hard way on the Palomino.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
c.traveler2
Moreno Valley,Ca.
Posted: 06/11/12 10:52am Link  |  Quote  |  Print  |  Notify Moderator
I got rid of the Lance plug years ago,replacing it with a bargman plug.
Lance PDF
2007 F-250 4x4 /6.0 PSD/ext cab/LB/camper pkg..Lance 815/ 85 watts solar panel
Travelingman2 Photo Website
Truck Camper Trip Reports
ridinpreacher
Round O, SC
Posted: 06/11/12 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Reddog1: is it a simple change from the 6-in lance to the 7pin?
ridinpreacher
Round O, SC
Posted: 06/11/12 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have found a 7 pin to 6 pin adapter at AgSouth for 8.99. Is this what I need for plugging a Lance camper into a 7 way?
And I have found a RV Camper trailer plug Y adpater on ebay. It plugs into 7 way outlet at the rear of truck; has a 12" long cord with 7 way to plug into trailer; has a 5 ft long cord with 7 way to go up in truck bed to plug in truck camper. Would this work with the 7 pin to 6 pin adapter and is 5 ft long enough to reach the cord that comes with the Lance camper?
This seems like a reasonable way to go. Total cost would be less than $60 and would seemingly require no splicing into wiring or drilling into truck bed.
Here is the link to this adapter http://www.ebay.com/itm/RV-Camper-Trailer-plug-Y-Adapter-5-cord-1MA-2FM-7?item=350324812632&cmd=ViewItem&_trks
Reddog1
El Dorado, CA
Posted: 06/11/12 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
I do not have a Lance, so I am hesitant to say yes. If Lance used the industry standard, it should be pretty straight forward. But to be fair, want is simple for some, is difficult for others. Most of the connectors I have seen, have their wiring instructions in the packaging.
Wayne
Reddog1
El Dorado, CA
Posted: 06/11/12 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
That appears to be right. As I previously stated, if Lance is wired to the industry standard, it should simply just be a "Plug-n-Play".
This is pretty much what I made up. At about $50 (including shipping), it is about what the parts cost for mine, and is a cleaner setup.
I agree.
http://www.ebay.com/itm/RV-Camper-Traile........M-7?item=350324812632&cmd=ViewItem&_trks
Wayne
barko1
las cruces
Posted: 06/11/12 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Wayne
Unfortunatley Lance seems to use their own plug that doesn't match up. I have to go pick up a Lance and this is making life harder. I found this: http://www.ebay.com/itm/270648510611?ssPageName=STRKEBIDX:IT&_trksid=p3984.m1952.l2649
 > Lance 6 pin
