Open Roads Forum
Print  |  Close
Topic: Lance 6 pin
Posted By: ridinpreacher on 06/10/12 05:07pm
Is there a plug adaptor to go from Lance 6 pin/way male cord end to the 7 pin/way female on the truck. Or is there a site to get a wire diagram to splice a Lance compatible 6 way female to the truck's wiring harness?
Posted By: Desert1667 on 06/10/12 09:00pm
Here is a Link to the lance wiring,
www.lancecamper.com/docs/trailer-owners-manual.pdf
Desert
Posted By: Reddog1 on 06/11/12 08:55am
I preferred to change the 6-pin on my TC to the seven pin. I originally used an adapter, but constantly had to hunt for it when I loaded my TC.
You can buy an adapter from most Auto parts stores, Walmart or RV parts stores. If your TC is wired correctly, should plug right in. "Plug-n-Play"
Wayne
Posted By: mkirsch on 06/11/12 10:29am
Be glad you can get the wiring diagram. I had to figure out the wiring the hard way on the Palomino.
Posted By: c.traveler2 on 06/11/12 10:52am
I got rid of the Lance plug years ago,replacing it with a bargman plug.
Lance PDF
2007 F-250 4x4 /6.0 PSD/ext cab/Lance 815/ 85 watts solar panel
Travelingman2 Photo Website
Truck Camper Trip Reports 3.0
travelingman210000 YouTube Videos
Posted By: ridinpreacher on 06/11/12 11:05am
Reddog1: is it a simple change from the 6-in lance to the 7pin?
Posted By: ridinpreacher on 06/11/12 01:52pm
I have found a 7 pin to 6 pin adapter at AgSouth for 8.99. Is this what I need for plugging a Lance camper into a 7 way?
And I have found a RV Camper trailer plug Y adpater on ebay. It plugs into 7 way outlet at the rear of truck; has a 12" long cord with 7 way to plug into trailer; has a 5 ft long cord with 7 way to go up in truck bed to plug in truck camper. Would this work with the 7 pin to 6 pin adapter and is 5 ft long enough to reach the cord that comes with the Lance camper?
This seems like a reasonable way to go. Total cost would be less than $60 and would seemingly require no splicing into wiring or drilling into truck bed.
Here is the link to this adapter http://www.ebay.com/itm/RV-Camper-Trailer-plug-Y-Adapter-5-cord-1MA-2FM-7?item=350324812632&cmd=ViewItem&_trks
Posted By: Reddog1 on 06/11/12 02:25pm
I do not have a Lance, so I am hesitant to say yes. If Lance used the industry standard, it should be pretty straight forward. But to be fair, want is simple for some, is difficult for others. Most of the connectors I have seen, have their wiring instructions in the packaging.
Wayne
Posted By: Reddog1 on 06/11/12 02:32pm
That appears to be right. As I previously stated, if Lance is wired to the industry standard, it should simply just be a "Plug-n-Play".
This is pretty much what I made up. At about $50 (including shipping), it is about what the parts cost for mine, and is a cleaner setup.
I agree.
http://www.ebay.com/itm/RV-Camper-Traile........M-7?item=350324812632&cmd=ViewItem&_trks
Wayne
Posted By: barko1 on 06/11/12 03:25pm
Wayne
Unfortunatley Lance seems to use their own plug that doesn't match up. I have to go pick up a Lance and this is making life harder. I found this: http://www.ebay.com/itm/270648510611?ssPageName=STRK[emoticon]EBIDX:IT&_trksid=p3984.m1952.l2649
Posted By: aroy924 on 02/09/13 11:34am
The reason you "shouldn't " change from the factory plug is that the standard 7 way plug can only accept 10 gauge wiring. The 12 volt side of your refrigerator in your camper requires 8 gauge wire. If you cut the wire and convert to a 7 way, the wire between the camper and your battery ( 10-12 ga) will become a fuse. If you go to your nearest Lance dealer, they can sell you the correct truck-side adapter.
If you never use the 12 Volt option on your refer, you won't need the bigger wire.
If you still plan on modifying your electrical plug, make sure you have the 8 gauge power and ground wires.
hope this answers some questions
Posted By: joe b. on 02/09/13 12:07pm
My Chevy came with the optional camper wiring installed and tied off under the cab. I bought the Lance 6 pin harness from a Lance dealer and installed it in the truck bed up near the front. I prefer to run #6 or larger wire for the + and - wires, run directly from the alternators/batteries. The truck also has the standard bumper 7 pin which I use when pulling our 5th wheel or adapt it to a flat 4, when dragging my boat. The 7 pin factory wiring is too small IMHO to charge the battery as quickly as I want it to do so. With the 5th wheel, it is strictly a campground queen and is plugged into shore power every night, so battery recharging is not an issue.
The TC is what we take on our long trips which involve mostly camping off the gird, so battery recharging while we drive is important to us.
joe b.
Stuart Florida
Formerly of Colorado and Alaska
2016 Fleetwood Flair 31 B Class A w/bunks
http://www.pajbcooper.com web site
Alaska-Colorado and other Trips posted
"Without challenge, adventure is impossible".
Posted By: KD4UPL on 06/11/12 03:31pm
A Lance 6 pin is like NOTHING else. It is not an industry standard 6 pin trailer plug. Adapters at auto parts places will not work. I don't know of any ready made adapter. You could cut off the Lance plug and install a 7 pin. It's not that hard. Lance uses there own plug and cable because they include extra heavy wiring and connectors for the + and - to help charge the battery better.
Posted By: ridinpreacher on 06/11/12 05:01pm
KD4UPL thanks for your clarification.
As for "you can cut off the Lance (6 pin plug) and install a 7 pin. It is not that hard."
Can you send the "procedure" or "color code" so that I would know "where to connect" each Lance wire to which pole on the 7 pin?
Or, is it straight forward from diagram available on Lance site by chance?
Posted By: wnjj on 06/11/12 05:29pm
Found this 2009 Lance brochure using Google. http://www.lancecamper.com/docs/09-owner-manual.pdf
Look on page 17.
I doubt it's changed over the years.
Print  |  Close
