Today while unpacking and cleaning our TT we noticed our underbelly had seperated and is hanging down approx. an inch. This is under our entrance door ( living room) and the length of the separation is approx. two feet.
I can see inside the gap and can see wood trimming attached to the plastic under belly, and can also see heat duct.
What I don't see are screws, clamps, glue and or silicone that previously held it up and in place.
Anyone with experience with this issue ? What holds this " Belly" up ?? What needs to be done to correct it?
First real issue with our TT..........lucky I guess !
Thanks for any suggestions !
2010 Flagstaff 26RLS
2012 Ford F-150 Screw Ecoboost H/D 3.73
2006 Toyota Tundra D/C (sold)
2001 Bantam B-19,(sold)
2003 Harley Road King
The whole family,
Cold ones in the cooler, good times ahead.
Mine is held up with self tapping screws with a washer. Should be an easy fix but I would put some silicone or some putty between the panel and the frame.
We installed a tank flusher on ours, so we had to remove the underbelly fabric. We reattached it using "GORILLA TAPE" (by the makers of Gorilla Glue) and it has stayed fastened for 4 years and that is quite a bit of travelling in rain/snow. I checked it just the other day to make sure it was still attached and I found another small section that had come loose. Put some more Gtape on it and hope it holds just as well.
