RV.Net Open Roads Forum: Class A Motorhomes: Micro Wave removal
 > Micro Wave removal
wagonmaster2
northcentral oklahoma
Posted: 06/12/12 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Sharp is another one of those companies we have to contend with that have no interest whatsoever is helping their consumers. I often wonder if they have any idea who is keeping them in business. Guess most of their products are supposed to be throw-away and they couldn't care less about helping to repair used ones.
If I remember right Sharp did at least have a parts list for the R1870, but by the time I found that I had already ordered the damper motor and switch from encompassparts.com/models/Shar1870 using their parts list. After thinking about it for a while as I was trying to find a repairman I decided to order the turntable motor and have it replaced at the same time thus costing only the price of the TT motor, and I ordered it from amiparts.com. Encompass did have the TT motor but I didn't recognize it on their parts list. Should have ordered all three pieces at the same time and would have saved a little shipping charges.
On mine the damper motor # was RMOTDA256WRZZ (Sharp lists it as RMOTDA217WREO), the switch was QSW-MA085WREO, the TT motor was RMOTDA211WREO. Don't be surprised if you find different part numbers. The lady at Encompass said she was finding 8 (I think that was the number) different part numbers for the exact same part. Every time they got a shipment in the number would change. Kind of like what Freightliner and Alliance is doing to us with their fuel/water filter numbers and micron numbers.
Good luck. It can get very frustrating.
Partstore.com is another source for these parts but they seemed to be a little higher on their prices.
Wagonmaster2
ArchHoagland
Clovis, CA, USA
Posted: 06/12/12 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
@wagonmaster... I'm curious why you wanted to also replace the turntable motor.
Where you having problems with it too?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
wagonmaster2
Posted: 06/13/12 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
No problem with the TT motor, but with my luck I figured since the damper motor conked out the TT motor would go the first time I'd go to use it after all the work getting the oven re-installed in the coach. The TT motor wasn't all that expensive and no extra labor to install the new one. Might have been an unnecessary expense but both motors look very similar if not exact so just thought if one went south the other would too, especially since the TT motor gets lots of useage.
Wagonmaster2
wagonmaster2
Posted: 06/17/12 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
her&I -
How are things going with your parts hunt? Hope you are finding everything you need and have someone to install the parts for you. I understand if you're really careful the parts can be replaced yourself but there are some really really hot spots in the oven you don't want to touch.
Good luck.
Wagonmaster2
her&I
Ontario, Canada
Posted: 06/18/12 07:20am Link  |  Quote  |  Print  |  Notify Moderator
wagonmaster2 wrote:
her&I -
Good luck.
Wagonmaster2
I got the oven out and it is at a Sharp authorized dealer. Just waiting now for pricing and then reinstall. It looks like this is a common occurances but no one has said if they know the cause.
JC2
Mo
Posted: 06/18/12 08:04am Link  |  Quote  |  Print  |  Notify Moderator
her&I wrote:
wagonmaster2 wrote:
her&I -
Good luck.
Wagonmaster2
As others have stated, this is a common problem for Sharp micro/convection ovens.
http://www.fixya.com/support/t127466-shuts_down_after_59_sec
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
her&I
Ontario, Canada
Posted: 06/18/12 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Got the call from the repair depot and the micro will be ready tomorrow. They had to change the switch and the motor. They say they have no idea what causes this problem so do not know what to avoid. Parts and labour came to $109. Now I have to struggle to get it back in place.
wagonmaster2
Posted: 06/20/12 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you got a decent price for the repair. Glad to hear they didn't try to hold you up. Now you just need a real hefty neighbor who can help you lift that monster up into place and hold it while the fasteners are attached.
Wagonmaster2
Bumbie
El Cajon, CA
Posted: 06/21/12 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I also was able to remove my Sharp and took it to a repair shop. Once repaired I found it easiest to find a medium sized box to fit over my gas stove. The box height was enough to almost reach rear mounting bracket on the wall. I was able to tilt the microwave, while resting most of the weight on the box, and seat the mounting brackets together. From there is was easy to lift and get the diagonal screws in by finger to hold it up. Hint.....put your screws & screw driver within reach. On my first attempt one of the screws rolled away and I had to let the micrwave down to retrieve it. An extra set of hands would have been helpful.
Good luck!!
'05 Safari Simba 33' and loving every minute!!!!
her&I
Ontario, Canada
Posted: 06/25/12 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
the saga has ended. Made up my mind to put that sucker back in today. 2 1/2 hrs, 1 skinned knuckle and 44 swear words and it is in. Word of advice: be sure the threaded end of the long angled screws are in their grooves before lifting mico wave into place. I didn't and had to take back down as one could not find the holes to screw into. Tried it and it works but afraid to leave it plugged in case of a reoccurance.
